Thread: Sound insulation
Results 1 to 9 of 9
  1. #1 Sound insulation
    Jul 2012
    Chicago
    I need to get that done in my car pretty soon. Since my budget is well... Nill. I'll probably be using a mix of Truck Bed liner, expanding foam, and peel n Seal.
    I'm curious to hear your guys' opinions and maybe see how you guys did your sound deadening.
    Thanks.
    -Carl
  2. #2 Re: Sound insulation
    I think Cole (Taz Magistererggerer or whatever it is) did that in his trunk.
    Might ask him how it turned out.
    The top swapped white 97-03 sedan guy with the dumb crazy wire tuck.
  3. #3 Re: Sound insulation
    Yoga city
    you want to actually kill sound or what is the purpose here? I like fat mat if your cheap, murdermat, or audio technix. Ive use all that i mentioned with out a hickup. After isntallation of first lair in my trunk, i killed most the sound i hear along the road.
  4. #4 Re: Sound insulation
    Jul 2012
    Chicago
    Quote Originally Posted by JTeske88 View Post
    I want to make my stereo sound better, but eliminating road noise would be a welcome side effect.
    Thanks for the ideas guys. I'm liking fat mat.
    -Carl
    I used either hushmat or fat at cant remember exactly which one. Killed a lot of road noise I ended up doing the inside of the doors and some of the floors with what I had left. Some spring time ill end up doing the rest of the floors and trunk. It's not super expensive but I would do it right instead of the peel n seal route.
    04 Comp G.
  6. #6 Re: Sound insulation
    Yoga city
    yeah thats why i mentioned those to him, its something if you dont want a nasty smell or mess in the summer. do it right so your panels dont bleed with goo
    GT Level Member maverickdog8's Avatar
    Bettendorf, Iowa
    Fat mat is cheap and works pretty well actually. It used to be like $65 for a 100 sq feet, but that was 2-3 years ago(unlabeled, but who cares).
    Also check out Rammat that's what I ended up using in the GP I currently have no complaints here.
    04 Comp G.
  9. #9 Re: Sound insulation
    Yoga city
    fat mat is up to around 50$ for 25sqft. I had just purchased some for a customers car. As long as you apply with heat if it cold youll be great. in the summer it goes on easy.
    Any of the matting ive stated is gonna clear up some your road noise and also help improve the audio charatiristics depending on how much and where you apply it.
  1. Trunk Lid Insulation?
    By pgr1940 in forum General Grand Prix Discussion
    Last Post: 12-27-2012, 11:05 AM
  2. Ok what is this sound.
    By MoarkatsINmuhtrailer in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2012, 01:10 PM
  3. Grinding sound when making sharp left and awful creak sound when going over bumps
    By rescuetoaster in forum Brakes/Suspension/Chassis
    Last Post: 03-04-2012, 10:06 PM
  4. Hood insulation or no?
    By Sabrewings in forum General Tech Discussion
    Last Post: 09-25-2008, 08:20 AM
