Thread: Hissing sound coming from rear speakers.....
Results 1 to 20 of 20
  1. #1 Hissing sound coming from rear speakers.....
    Nov 2012
    Tracy, CA
    I have an '04 GTP Comp G with the premium factory sound system. On and off I hear a hissing sound coming from the rear speakers only, even if the sound system is OFF.
    The hissing speeds up and slows down with engine speed. Weird thing is that it appears to start and stop if I hit a good bump in the road..... at least that how it seems..... I did have some work done on the AC system, condenser change, a few months ago and I believe the first time I heard it was right after that.. But now it's happening more.. Any ideas what it could be ? Thanks, and Happy Thanksgiving !!!!!
  2. #2 Re: Hissing sound coming from rear speakers.....
    Do you have anything hooked up to the cigarette lighter outlet or an fm modulator or anything?
  3. #3 Re: Hissing sound coming from rear speakers.....
    Nov 2012
    Tracy, CA
    Yes .. I am using a cigarette lighter power supply for a satellite radio and an FM modulator to get the satellite signal into the car radio......
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Even if the radio is off the monsoon amp is not. It provides function for the door chime and on star. It remains on for a minute or more after doors have been closed and sometimes until the bcm goes to sleep.
    I speculate if your hearing the hissing from your rears those outputs are likely taking a dump.. could be one or more solder joints on the amp board as well since u hear it over bumps
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  5. #5 Re: Hissing sound coming from rear speakers.....
    Nov 2012
    Tracy, CA
    Quote Originally Posted by rperry435 View Post
    So what do you mean by "dump" ? It seems that a good bump will cause the hising in the back to start..... sometimes it just starts on it's own ... It continue at times even after the car is stopped and the ignition and radio is OFF. The FM modulator for my satellite radio doesn't seem to have anything to do with the hiss,, since I have totally disconnected it and I can still get the hiss in the rear speakers ..... What can I check ? Can not find a ground up in the trunk where the amp is mounted ..... is there one there ? Thanks.....
  6. #6 Re: Hissing sound coming from rear speakers.....
    Thats probably causing your noise.
  7. #7 Re: Hissing sound coming from rear speakers.....
    Nov 2012
    Tracy, CA
    I disconnected the plug from the cigarette lighter socket, which turns off the fm modulator, but I still hear the hissing sound intermittently.....
    GT Level Member Erics00LS's Avatar
    Lindenhurst, IL
    buy a bluetooth transmitter
    '03 Buick Park Avenue Ultra - a few bolt ons
    http://www.facebook.com/groups/greatlakesareacarenthusiasts
    Oct 2011
    MI
    Taking a dump usually means they are going to **** lol sorry couldn't help my self
    There is nothing you can do but replace the amp sorry...The hissing is one of the symptoms they have. Eventually it won't work at all or you'll lose certain channels (speakers.)
    Only thing you could try before getting a new one is open it up and if you can solder.. If there's a bad solder point you could attempt to fix it but typically they just get replaced because the outputs burn up and don't work or hiss.
  10. #10 Re: Hissing sound coming from rear speakers.....
    Pennsylvania
    Quote Originally Posted by p coico View Post
    Isn't this a grounding issue?
    Oct 2011
    MI
    He can check his ground and ohm it out but I've seen the hissing problem in many grand prixs and g6's with the monsoon amps.. He'll bose ones do it too. new amp always fixes the problem
    Typically in aftermarket stuff a buzzing or whine with rpm is a ground or interference issue.
  12. #12 Re: Hissing sound coming from rear speakers.....
    Nov 2012
    Tracy, CA
    \ Thanks guys ...... The change in the pitch of the hiss with engine speed made me think it might be a ground issue.... Also, how it can come and go with a good bump in the road mage me think that way,, but I guess that could also be a bad solder joint in the guts of the amp.... This mounted in the trunk, so if I want to check the ground before resorting to buying a new one, where is the ground and how do I check it ??? Also, if I need to buy a new amp, any recommendations as to make and model ???? Thanks .....
    Oct 2011
    MI
    The amp takes some normal vibrations the car feels there is no rubber feet or anything like that. Plus it's mounted upside down.
    If I remember correctly there's a thick orange and black. You would need a multi meter and just select the ohm scale. From ground anywhere in the car or the battery itself to the thick black wire. if the resistance is too high it can cause issues. But again I assure your that's not your issue.
    The 8 digit gm part number is on the bottom BUT do yourself a favor, call a local dealership parts department give them the last 8 digits of your Vin. Usually the old part number is superseded and a newer revised amplifier is available that will never have the same issue again.
  14. #14 Re: Hissing sound coming from rear speakers.....
    Nov 2012
    Tracy, CA
    Thanks rperry ..... Any idea what these cost these days .....
    Oct 2011
    MI
    I'm guessing but Between 150-250
    When you call the dealership to get a price ask what the new part number is and search for it online that way you won't get stuck paying list price. I think some people go to rock auto.. Gmpart direct seems pretty close to my price when I compare them against my cost at work.
  16. #16 Re: Hissing sound coming from rear speakers.....
    Nov 2012
    Tracy, CA
    Thanks again rperry !!!!! I will follow your advce and get back to the forum with how I make out .... may take a week or more,,, with the holidays and this not being a "Car Down" situation ......
    Oct 2011
    MI
    I feel ya on that.
  18. #18 Re: Hissing sound coming from rear speakers.....
    Nov 2012
    Tracy, CA
    Actually, the fix was an easy one ...where the wires for the left rear speaker pass thru the hole in the metal frame of the shelf under the rear windshield, one of the wires was pressing against the sharp metal edge and its insulation was actually being cut.
    I moved the wire and wrapped it with electrical tape to keep it away from the metal edge and that fixed it !!!! Problem solved for next to nothing ..... It was a ground loop issue after all .....
    Oct 2011
    MI
    Awesome to hear you got it figured out. Not a ground loop though lol..thats just a plan old short if the insulation was cut and rubbing on metal.
    Sent using my Galaxy SIII on Tapatalk 2
  20. #20 Re: Hissing sound coming from rear speakers.....
    Nov 2012
    Tracy, CA
    Well, it wasn't a complete cut into the insulation, so I don't think it was a short.. That would have been bad... It was enough of a cut to allow the speaker signal to pick up noise from the car body / ground ..... Either way, so far so good... it's been weeks since I have heard the noise once I wrapped it in tape....
  1. HELP! Hissing sound after drilling though firewall
    By Jomamma in forum Audio, Security & Visual Electronics
    Last Post: 02-05-2012, 11:26 PM
  2. Squeaking sound coming from rear wheel
    By skeelo58 in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2012, 06:20 PM
  3. snap or spark sound coming from speakers only with stock deck
    By gpse2000 in forum Audio, Security & Visual Electronics
    Last Post: 12-27-2011, 05:32 PM
  4. Brakes make a hissing sound
    By supercharged98 in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2010, 09:09 PM
  5. paper flapping sound coming from the rear manifold
    By gpgt2002 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-03-2010, 12:35 AM
