Thread: HELP! Hissing sound after drilling though firewall
Results 1 to 19 of 19
Jomamma HELP! Hissing sound after... 02-03-2012, 07:08 PM
KeithGTP03 Re: HELP! Hissing sound after... 02-03-2012, 07:15 PM
Jomamma Re: HELP! Hissing sound after... 02-03-2012, 07:24 PM
Jomamma Re: HELP! Hissing sound after... 02-03-2012, 07:49 PM
simbah Re: HELP! Hissing sound after... 02-03-2012, 08:09 PM
Swiggles You could probably just tape... 02-03-2012, 08:51 PM
SlowNA06 Re: HELP! Hissing sound after... 02-03-2012, 09:47 PM
KeithGTP03 Re: HELP! Hissing sound after... 02-03-2012, 11:29 PM
SlowNA06 Re: HELP! Hissing sound after... 02-03-2012, 11:57 PM
Jomamma Re: HELP! Hissing sound after... 02-03-2012, 11:38 PM
KeithGTP03 Re: HELP! Hissing sound after... 02-03-2012, 11:44 PM
Jomamma Re: HELP! Hissing sound after... 02-03-2012, 11:56 PM
KeithGTP03 Re: HELP! Hissing sound after... 02-04-2012, 12:06 AM
KeithGTP03 Re: HELP! Hissing sound after... 02-04-2012, 01:13 AM
Jomamma Re: HELP! Hissing sound after... 02-04-2012, 06:37 PM
develand Re: HELP! Hissing sound after... 02-05-2012, 12:42 PM
Jomamma Re: HELP! Hissing sound after... 02-05-2012, 11:26 PM
  1. #1 HELP! Hissing sound after drilling though firewall
    Howell, NJ
    First let me start off by saying that I am new to the forums. I bought a brand new GTP Monday and I decided to register on the forums yesterday.
    Today I decided that I would switch all of my old speakers/subs/headunit from my old grand prix to my new gtp. Having already done this in my old grand prix I decided to drill though the rubber grommet located under glove box. I made sure to stay away from the bundle of wires. While beginning to drill the the bit decided to go in an unintended direction and hit the bundle of wires. At the time I recall hearing a little bit of a hiss. I noticed that it was getting dark anyway and i decided to call it a day.
    After cleaning up my car a bit I decided to take it for a run to hear the newly installed speakers. Immediately after starting it I noticed a hissing noise coming from where I drilled. The car still runs the same, and the AC/Heat work. However, I did noticed that it made different hissing noises when I changed the air conditioning from max, head, feet, defrost etc.
    Please help! What is this noise! WHAT DID I DOOOOO!
  2. #2 Re: HELP! Hissing sound after drilling though firewall
    Houston
    What year is your car? Mine is an 03 and It has a vac line that runs the HVAC. This is on behind the center console on the passenger side. It runs from here through the grommet on the the passenger firewall and connects to the tree on the supercharger
  3. #3 Re: HELP! Hissing sound after drilling though firewall
    Howell, NJ
    I have a 97 2 door. I tried looking for the first picture but no luck. Where do I go from here.
  4. #4 Re: HELP! Hissing sound after drilling though firewall
    Howell, NJ
    Well thats what it is. I unplugged that vacuum line from the super charger tree and no hissing from inside. Where can i get a new vac line?
  5. #5 Re: HELP! Hissing sound after drilling though firewall
    GTP Level Member simbah's Avatar
    Lala land
    your local hardware store or auto parts store just take a sample with you and tell them you need that size and however long you want
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
    Quincy, Mass
    You could probably just tape it up really well since its just a vac line for the hvac. Unless you cut it up really bad
    No more GP 04 Impala SS Indy:
  7. #7 Re: HELP! Hissing sound after drilling though firewall
    Pennsylvania
    Quote Originally Posted by Swiggles View Post
    See, here's the problem with that: that vacuum line connects to multiple spots and will cause issues. Fix it right the first time.
  8. #8 Re: HELP! Hissing sound after drilling though firewall
    Houston
    Quote Originally Posted by SlowNA06 View Post
    Its a straight line that runs from the tree to the HVAC. It doesnt connect to anything else. But I agree, fix it right. Get at least 8ft of vac line and rerun that line.
  9. #9 Re: HELP! Hissing sound after drilling though firewall
    Pennsylvania
    Whut?
    The vacuum manifold connects to no less than the intake, brake booster, and bypass valve vacuum actuator, as well as the HVAC.
  10. #10 Re: HELP! Hissing sound after drilling though firewall
    Houston
    Whut?
    Yes, but the HVAC line runs directly from the manifold to the HVAC. You can just cap off the HVAC port on the manifold and it wont affect anything. You'll just have issues switching levels on your heater/ac.
  11. #11 Re: HELP! Hissing sound after drilling though firewall
    Howell, NJ
    There's a chance that i may have also clipped some of the wires. Everything is working fine. Ill check to see if i hit anything in the morning.
  12. #12 Re: HELP! Hissing sound after drilling though firewall
    Houston
    Yeah, that would be a nightmare. Those wires are not easy to get to if they need replacing.
  13. #13 Re: HELP! Hissing sound after drilling though firewall
    Howell, NJ
    Tell me about it.
    What are those wires for?
  14. #14 Re: HELP! Hissing sound after drilling though firewall
    Houston
    Quote Originally Posted by Jomamma View Post
    Tell me about it.
    I believe that they run to the fuse box in the glove box
  15. #15 Re: HELP! Hissing sound after drilling though firewall
    Houston
    Yeah, removing it without sealing off the port will introduce a big vac leak. Sounds like you just clipped it, but a vac leak is a vac leak. And it will get worse before it gets better.
  16. #16 Re: HELP! Hissing sound after drilling though firewall
    Howell, NJ
    Thanks for the help. There was only a small hole in the vac line so i patched it up with some tape. I got lucky. The whole process to checking the wires and reparing the hole took about 4 hours. I hated every frustrating moment of it...
  17. #17 Re: HELP! Hissing sound after drilling though firewall
    GTP Level Member
    Nov 2011
    Kansas
    FYI, future reference, my 08 has that giant rubber piece too. I just taped my amp power wire to a plastic coat hanger, and pushed it through the existing hole....
  18. #18 Re: HELP! Hissing sound after drilling though firewall
    Howell, NJ
    Yeah that's what I did but I instead made a cut though one side of the boot and just fed it through there.
    I forgot how load these subs were.
  1. Drilling and Tapping Phenolic Spacer
    By ls1camino in forum General Tech Discussion
    Last Post: 06-14-2011, 07:19 PM
  2. Hissing noise at the Firewall
    By darkfox1009 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2011, 04:43 PM
  3. Brakes make a hissing sound
    By supercharged98 in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2010, 09:09 PM
  4. Drilling a Tstat????
    By WHT98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2009, 06:49 PM
  5. Drilling holes in the trunk???
    By MysticStyl3z in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2008, 10:58 AM
