Thread: Hissing sound coming from rear speakers.....
Results 1 to 20 of 20
  1. #1
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    He can check his ground and ohm it out but I've seen the hissing problem in many grand prixs and g6's with the monsoon amps.. He'll bose ones do it too. new amp always fixes the problem
    Typically in aftermarket stuff a buzzing or whine with rpm is a ground or interference issue.
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  2. #2 Re: Hissing sound coming from rear speakers.....
    Nov 2012
    Tracy, CA
    Quote Originally Posted by rperry435 View Post
    \ Thanks guys ...... The change in the pitch of the hiss with engine speed made me think it might be a ground issue.... Also, how it can come and go with a good bump in the road mage me think that way,, but I guess that could also be a bad solder joint in the guts of the amp.... This mounted in the trunk, so if I want to check the ground before resorting to buying a new one, where is the ground and how do I check it ??? Also, if I need to buy a new amp, any recommendations as to make and model ???? Thanks .....
  1. HELP! Hissing sound after drilling though firewall
    By Jomamma in forum Audio, Security & Visual Electronics
    Last Post: 02-05-2012, 11:26 PM
  2. Squeaking sound coming from rear wheel
    By skeelo58 in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2012, 06:20 PM
  3. snap or spark sound coming from speakers only with stock deck
    By gpse2000 in forum Audio, Security & Visual Electronics
    Last Post: 12-27-2011, 05:32 PM
  4. Brakes make a hissing sound
    By supercharged98 in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2010, 09:09 PM
  5. paper flapping sound coming from the rear manifold
    By gpgt2002 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-03-2010, 12:35 AM
