Thread: How do I replace Trac Off bulb?
Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
  1. #21 Re: How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    Actually I think Ill just swap out my Low Trac for my Trac Off light. Who really needs the low trac light lol? Its kind of obvious when your tires are spinning..
    I eventually worked the bulb out of the blue base, but now Im left with two small wires coming out of the blue base. They make it to just about the top. Are they supposed to be there? Can i reuse this base? Or can i just buy a new one at autozone?
  2. #22 Re: How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    Simple questions lol can someone please answer so I can put my dash back together..
  3. #23 Re: How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    Okay so I went and bought bulbs anyways and replaced it and the light works.
    But it doesn't ****ing work accurately. -.-
    it just says off all the time even though I can still switch it on and off.
  4. #24 Re: How do I replace Trac Off bulb?
    Houston
    The bulb is probably in backwards.
    *Edit* you didn't go with LED's, so that won't matter. Is your ABS light on as well?
  5. #25 Re: How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    Yeah the abs light is out so I assume they're both on. It might be my passenger hub as the wheel has some play. Is this possible?
  6. #26 Re: How do I replace Trac Off bulb?
    Houston
    Thats the usual suspect.
  7. #27 Re: How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    How much are the hubs for these cars?
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Usually around 100. I put Timkin hubs in for 140 each. 3yr warranty.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  9. #29 Re: How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    shiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii iiiiiiiiiiiiit
    uhhh i guess ill hae to do those some time but im okay with that,
  10. #30 Re: How do I replace Trac Off bulb?
    St. Louis
    "it just says off all the time even though I can still switch it on and off."
    "Yeah the abs light is out so I assume they're both on"
    This is confusing. What you are saying is the the TRAC OFF light is lit up all the time, yet your ABS light on the dash is not on?? Maybe I'm not following....
    I've never been able to turn my trac control off and on using the button when the light is on all the time and there is an ABS light on constantly on the dash. When the ABS light is on Trac control is disabled and button won't do anything. I drove my 00 GT around like this for over 6 months and trac control was always off and pressing the button could not change that.
    IF you have an ABS light on then get that hub changed and I'd bet that the trac control button will work as designed. And yes, Timkin hubs FTW. Check out RockAuto for them, seems to be a good place to get them. If you need one in a hurry then I think Autozone carries Timkin hubs but the price is higher.
    Depending on how much play is in that hub it may not even be that, it could be the wiring or the connector to the hub. My front pass. side wire harness was rotted out about 7 inches back from the connector causing my ABS light. Took a while and a voltmeter to find that one.
  11. #31 Re: How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    It's not on but it doesnt work at all so i assume it burnt out from being all the time. I assume the hubs needed to be changed at like 80k miles or something and they never did it so the bulbs burnt out. I still have abs and traction control and the button turns it on and off but the light stays on.
    Ill check the connectors too, but there is some play im pretty sure.
    Is there a video anywhere of someone checking a hub or something to compare to?
  12. #32 Re: How do I replace Trac Off bulb?
    St. Louis
    Possibly, never really needed a video. Just jack the car up until the front wheels clear the ground, grab the tire at 12 and 6 and try to wiggle it top to bottom. If you have play it will show up here. If no play, then look elsewhere for ABS/trac control issues. The only other way it can cause issues is if the wire that leads from the hub to the harness gets broken internally on the hub, then you have no choice but to change the entire hub as it is all 1 piece.
    It would be a good idea to clean the connectors out and add a little dielectric grease to them to keep the corrosion down. If you get in a bind let me know and I'll see if I can help.
    FYI, when you go to change the hub, make sure you have a large enough socket to remove the old spindle to hub nut and install the new one. Often the replacement one is a different size. Somewhere around 34-36mm depending on manufacturer IIRC.
  13. #33 Re: How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    It has some play, like its not like the wheel is wobbling out of control but i can def see some play. I just dont know if its enough to count as needing to replace the hub.
    But ill check the connections and what not more today when i go back to the shop, thanks.
    May 2011
    United States
    Any play=replace hub.
    Sent from my Droid
  15. #35 Re: How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    Oh yeah okay i researched a bit more and its definitely needing replacing. how important is replacing a wheel hub? I rarely drive on the highway also. Max speeds are usually 50 and under.
  16. #36 Re: How do I replace Trac Off bulb?
    michigan
    Only on gpf can there be a thread about changing a bulb that is two pages long........so far. Lmfao!!!
    May 2011
    United States
    Just change it! Lol
    Sent from my Droid
  18. #38 Re: How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    Quote Originally Posted by twol8uluz View Post
    Lmfao so true.
    And i cant just change it i dont have the money atm, but i was saving for tint. So if i could just get tint and wait a bit to replace the hub id be more happy.
  1. Abs/trac off
    By Wingsfreak9 in forum Brakes/Suspension/Chassis
    Last Post: 09-29-2012, 08:52 PM
  2. ABS/Low Trac
    By Below Average Joe in forum General Grand Prix Discussion
    Last Post: 06-14-2012, 10:32 AM
  3. How Do I replace my shifter console bulb?
    By k3sevens in forum Introductions/Noob Questions
    Last Post: 01-24-2012, 03:35 PM
  4. 04+ HVAC bulb replace with LEDs cheaply..
    By industrialfish in forum How To Write-Ups/Tech Tips
    Last Post: 11-25-2011, 07:25 PM
  5. No ABS or Trac
    By Hamsalad2 in forum General Tech Discussion
    Last Post: 04-06-2010, 03:00 PM
