Thread: How do I replace Trac Off bulb?
Results 1 to 20 of 38
  1. #1 How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    My trac control light doesnt work, so i never know when my trac is on or off.
    Can someone tell me how to replace this light and what bulb? Every time i search i just get trac off/abs light on problem results.
  2. #2 Re: How do I replace Trac Off bulb?
    Houston
    Remove the dic and twist out old bulb and twist in new bulb. They are just 194 twist in's. Might as well replace all three since you're back there.
  3. #3 Re: How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    No idea how to remove the dic. (they really shouldve named it something else)
  4. #4 Re: How do I replace Trac Off bulb?
    Houston
    Pull off the dash trim and there is a clip on the left side of the DIC. Push that in and it comes right out.
  5. #5 Re: How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    Thank you. Not knowing when i have tc on or off is really frustrating haha. Will do this asap. I think my trim is cracked though. I can see a small crack in it going over the gauge cluster...
  6. #6 Re: How do I replace Trac Off bulb?
    St. Louis
    Very possible. You probably also have some missing trim clips that have been broken off from a previous removal. Mine has 2 missing ones but still sits on there just fine.
    I thought mine was out but once I got the DIC out the bulb was fine. It was actually the 2 contact fingers on the bulb housing not making a good connection to the PCB that is on there. Cleaned that up, cleaned the bulb holder contacts and bent them down slightly and reinstalled. Wala. TC bulb works fine.
  7. #7 Re: How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    Can i buy trim clips at autozone?
  8. #8 Re: How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    Are you ****ing joking? These dic clips do not budge AT ALL.
    Ohio
    Quote Originally Posted by PioneerGTP View Post
    Just go put an apron on now -_-
  10. #10 Re: How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    What do you mean...
    And there's two clips. I can't get either of them to push far enough.
    Ohio
    Push from the outside of the left clip with a good flat head, and it will pop out on its own.
  12. #12 Re: How do I replace Trac Off bulb?
    Jul 2012
    can you change it so it glows blue?
  13. #13 Re: How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    Okay the clips literally dont fit under the plastic little guard thing theyre under. Taking off the dic faceplate i mean. wtf? I have all of them off but two because the two on the left dont fit under the plastic.
    Ohio
    Quote Originally Posted by Tyler Sharp View Post
    Yes
  15. #15 Re: How do I replace Trac Off bulb?
    Jul 2012
    do i have to get a blue bulb or what? cause my gauges are all blue now cause i put a glow face plate on that and i want to match
    Ohio
    Research putting leds in
  17. #17 Re: How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    Seriously the clips are too big to take out. What the hell do i do?
    Ohio
    The clips don't come out?!
  19. #19 Re: How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    I had to bend the plastic guard things t oget them out. But yeah, one bulb is broke. One is there. Two are missing. How ****ed am i?
    Nevermind just one is broken i think. I dont think two belong in the two empty holes.
  20. #20 Re: How do I replace Trac Off bulb?
    Sep 2012
    St Louis Missouri
    GM Parts Direct: Your direct source for Genuine GM Parts
    Should i order this one? The bulb is literally shattered in the blue base so i wouldnt be able to get it out. Im sure it was burnt out in the first place and someone else tried to change it and broke it.
    Wow wtf in the end it came out to be 20 dollars with shipping. **** that. Do they have the blue base things at autozone?
  1. Abs/trac off
    By Wingsfreak9 in forum Brakes/Suspension/Chassis
    Last Post: 09-29-2012, 08:52 PM
  2. ABS/Low Trac
    By Below Average Joe in forum General Grand Prix Discussion
    Last Post: 06-14-2012, 10:32 AM
  3. How Do I replace my shifter console bulb?
    By k3sevens in forum Introductions/Noob Questions
    Last Post: 01-24-2012, 03:35 PM
  4. 04+ HVAC bulb replace with LEDs cheaply..
    By industrialfish in forum How To Write-Ups/Tech Tips
    Last Post: 11-25-2011, 07:25 PM
  5. No ABS or Trac
    By Hamsalad2 in forum General Tech Discussion
    Last Post: 04-06-2010, 03:00 PM
