Thread: heater still not working
Results 1 to 12 of 12
  1. #1 heater still not working
    Jul 2012
    i have a 2000 gp with the automatic heater/ac controls and my blower motor stopped working 2 weeks ago and ive changed the blower motor that didn't work so i was told that it might be the control box and i changed that and still nothing, i don't know what else to change any suggestions? need help its getting cold in the mornings
  2. #2 Re: heater still not working
    you try swapping the blower motor resistor yet? or test for power at the fan plug as well. check your fuses if not done already.
  3. #3 Re: heater still not working
    Jul 2012
    i was told there was no resistor in it since it was an automatic and ive checked fuses and testes wires and there all good
  4. #4 Re: heater still not working
    so you have power at the plug for the fan?
    and you should have a blower motor resistor, its located behind the fan.
    https://www.google.com/search?q=2000...&bpcl=35466521
  5. #5 Re: heater still not working
    Jul 2012
    the first guy said it wouldn't have a resistor cause it was an automatic but i didn't believe him , ive had 2 different people look at it and the second guy say said it had power but im not sure
  6. #6 Re: heater still not working
    if you have a 3 dollar test light you can find out for yourself.
  7. #7 Re: heater still not working
    Jul 2012
    sadly i don't i will buy one tomorrow
  8. #8 Re: heater still not working
    Jul 2012
    i bought one and no power to the blower wires
  9. #9 Re: heater still not working
    you did have the key turned to run and the fan turned to any speed right? if so, test for power before the resistor.
  10. #10 Re: heater still not working
    Topeka, KS
    You have a blower motor resistor. I have digital HVAC controls too and I have a resistor. Whomever told you that you don't doesn't know what they are talking about. The plug that plugs into your blower fan is connected to the resistor. Replace that box and you will be in business.
  11. #11 Re: heater still not working
    SE Level Member Patrick551's Avatar
    Jul 2012
    Des Moines, Iowa
    Sometimes they are called reostats. You can tell when one is starting to go out on you only have one or two fan speeds. Replace this and you should be in business.
  12. #12 Re: heater still not working
    Jul 2012
    ha thank you guys ill take it off at school tomorrow and i got two of the screws out i just cant get the damn third one in the back
  1. Heater not working
    By JulieC in forum General Tech Discussion
    Last Post: 03-01-2012, 03:05 PM
  2. Heater Not Working
    By teamfbody in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-01-2011, 11:05 PM
  3. Heater stopped working
    By ls1camino in forum General Tech Discussion
    Last Post: 11-08-2011, 02:36 PM
  4. Heater not working properly
    By dms13 in forum General Tech Discussion
    Last Post: 12-13-2010, 07:16 AM
  5. Troubleshooting Help? DIC & heater/AC not working
    By TMC in forum General Tech Discussion
    Last Post: 12-12-2010, 02:30 AM
