Yes, you want to fuse the distribution block as well. Because at the distribution block, it splits into two or more smaller lines. (IE: A 4 gauge line splits into 2 8 gauge lines). The smaller power lines require a smaller current fuse. As for amping the 6x9's, its up to you. If you are going for staging, then no. If you're going for loud, then yes.
