ok ill do my best for a write up on this
here is the link for the bulbs i replaced the stock ones with
194 LED Bulb - 6 SMD LED Wide Angle Wedge Base | Miniature Wedge Base LEDs | LED Car Bulbs | Super Bright LEDs
here is the link for the extra bulbs i added in the front and rear floor boards to make it brighter
LSMCC series Constant Current SMD LED Sign Module | LED Module Strings | LED Light Strips & Bars | Super Bright LEDs
i used a kit similiar to this one to connect the new wires that i added into the car
Wire Connectors Terminal Kit # TK-500 by GB Electrical
and i used a tool called wire splicers to strip the new and old wires where i cut them so i could splice them together
Then its easy from there once you get the new wire spliced and put into place. you just run it thru the siding in the car or under carpet your choice to the back where you want the lights to be. and the wiring i used was the wiring that runs to the stock bulbs in the floor board. If you want more pictures or information let me know and i will go take some more
