Quote Originally Posted by DrSnazzy View Post
1. I'd suggest getting a class d monoblock for the subs,
2. Strut tower bolts are good places to ground just make sure the paint under the bolt is removed.
Sent from my LS670 using Tapatalk 2
I agree with that, however, its hard to find those monoblocks at a budget price. Those amplifiers are some high-end pieces of equipment. For budget, a dual channel would work fine bridged. But if the subs don't match right, bridging can cause a lot of heat with those cheapies and send the amp in protection if its equipped with it. Also, the strut tower bolts are a good place if you remove the paint underneath and add a washer to add better connection.
