Thread: Help with rear speakers
Results 1 to 7 of 7
  1. #1 Help with rear speakers
    Jul 2012
    Newark
    I bought 6x9 kicker speakers but I have the monsoon audio in my 06 gxp.The original speakers have four wires going to them...two for the mids two for the lows for the old speakers...what wire combo do I need or what do I have to do to get it to work with all the signal going to my kickers
  2. #2 Re: Help with rear speakers
    Topeka, KS
    Did you get components ?
  3. #3 Re: Help with rear speakers
    Jul 2012
    Newark
    No but I think I'm going to have to cause I can only get highs or I get lows...if I hook all four wires up it all distorted.
  4. #4 Re: Help with rear speakers
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Can I have the speaker model? Does it have a built in crossover?
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  5. #5 Re: Help with rear speakers
    Yoga city
    best way to do this would be to desoilder the tweeter fromt he leads and soilder it back to the appriate wires. but then again if the ohms dont match you will end up with lower power resulting in less output.
  6. #6 Re: Help with rear speakers
    GTP Level Member simbah's Avatar
    Lala land
    If you want to use your new speakers and the stock wiring this is what you're going to have to do. Take the wires from the stock 6x9 and wire them to the speaker connection on the new speaker, now comes the daring and tricky part, you are going to have to wire the other set of wires to the wires that are inside the speaker that go to the inner speaker, yes you may have to cut those little wires on the new speaker, am I making sense yet. This has been done before by many other members, I don't remember their names though. the only other solution is to completely replace the Monsoon amp with another aftermarket amp and just wire the speaker normally. If you do the first part of this description you may not be able to do the second part. The choice is yours. One other solution is to wire just the high set of wires to the new speaker(not the blue wires) and then just add an amp and subwoofer to get the lows that you want. The Monsoon amp has a total output of 270 watts of power for all 6 channels, the two 6x9s are subwoofers wired in parallel with a smaller full range speaker inside of the 6x9. This is why you get distortion, you are taking a signal that has gone thru a croosover within the Monsoon amp, and combining the signals at the speaker.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  7. #7 Re: Help with rear speakers
    Jul 2012
    Newark
    It don't have a built in crossover...I took the tweeter leads off and tried it that way but the signal going to the tweeters just sounds likes###....how bad is it to replace the monsoon amp cuz I got a smaller kicker amp from my old car
  1. Rear 6x9 Speakers
    By MARK6679 in forum Audio, Security & Visual Electronics
    Last Post: 01-14-2012, 02:53 AM
  2. GTP rear speakers
    By xsvtank in forum Audio, Security & Visual Electronics
    Last Post: 08-21-2010, 05:18 PM
  3. DIC and Rear Speakers
    By mvp828 in forum Audio, Security & Visual Electronics
    Last Post: 08-02-2010, 12:29 PM
  4. Rear speakers
    By josemolina2008 in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2010, 02:21 PM
  5. Rear speakers cut out??
    By 91z in forum Audio, Security & Visual Electronics
    Last Post: 09-16-2008, 09:53 PM
