Thread: ingnition problem
Results 1 to 7 of 7
  1. #1 ingnition problem
    Jun 2012
    illinios
    my ingnition key will not turn back in lock postion to release the key. any ideas? new guy here
  2. #2 Re: ingnition problem
    under the column is a plastic button, it pops off, if you stick a pen or stick up there it will hit lever and let you turn your key back. chances are you have a shift lock solenoid problem.
  3. #3 Re: ingnition problem
    Jun 2012
    illinios
    where is the shift lock solenoid located? where can you buy one to replace ? thank for your help
  4. #4 Re: ingnition problem
    heres a link to others with the same problem http://www.grandprixforums.net/key-s...nder-7824.html
  5. #5 Re: ingnition problem
    Jun 2012
    illinios
    i got the key out but iam able to shift out of park with no key in
  6. #6 Re: ingnition problem
    the sensors all work together, you have one in the shiftier as well, one quit the other dont what to do most of the time. they work together. with the brake pedal. unless thats been a problem before this.
    when you fix the ignition solenoid the other one should work again. i believe. but could be wrong lol
  7. #7 Re: ingnition problem
    Sep 2011
    Chicago
    check your battery, my 98 did the same thing, found the battery was dead.
  1. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  2. next problem
    By nicks98gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-13-2011, 10:51 PM
  3. A/C Problem
    By KSGTP97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-13-2010, 08:55 AM
  4. BCM problem
    By Paulio0907 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2009, 04:41 PM
  5. Problem!
    By pure in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-13-2009, 11:07 PM
