Thanks to this forum, I seem like an expert mechanic to my wife...so far I have been able to diagnose and fix every problem I've encountered w/ my 97 Grand Prix GTP from forums and threads on this site. I found numerous threads documenting my problem w/ the modes not working on my Dual Climate Control (vacuum leak found under windshield washer fluid reservoir), blower motor whining and fixing, and latest one, my a/c blowing cold air from passenger side and hot on drivers (recharge a/c).
So I recharged the a/c last Wed. It blew nice, ice cold air from both sides. Two days later, both sides were hot, drivers side hotter than passenger. The line that I added the 134a to is ice cold (back top behind engine). I'm not 100% that the compressor is kicking on as I'm definitely no mechanic, but the car does do something when I turn the a/c on (may be the belt kicking in, but idle drops momentarily and you can hear a new constant humming). Is there an easy way to check if the compressor is shot? I would rather not waste the $40 I spent on the recharge, and don't have a shop to dispose of the stuff if I have to take the compressor off.
I haven't seen this problem on any other thread, so I have started a new one...hopefully someone has had this problem before. The car has 119k on it.
Thanks for all your guys' help...it has been greatly appreciated!
