Ok, got it figured out.
The problem was that I received a newer unit with old directions. The directions say to connect the orange and green wire to pin 14 on the car. On this unit, that wire was deleted and it is now the yellow/green wire that needs to be connected to the car. I hooked this up and it immediately found the car and programmed itself with out touching any buttons or doing anything, only problem is that my cd player stopped working. turns out that my head unit is to modern for this aswc, so i need to send it to the company, or take it in to a local dealer and have it flashed with the newest firmware for it to work properly.
maybe this will help you out burgendybullet. If you uswc has the yellow/green wire instead of the orange/green. that is the one that needs to be hooked up.
