Quote Originally Posted by buickman104 View Post
Nope. I have a 2000 GTP with an Axxess and Kenwood deck. Did you splice in the wire that comes directly from the harness? There is a wire I forgot what color that you have to cut before it reaches the main harness and splices directly to the axxess.
I did splice it and it is a blue wire from the origional harness but there was a green wire that connects to nothing so i was slightly confused by that.
Quote Originally Posted by nik12937 View Post
The wires specified in the instruction manual that came with my ASWC were completely wrong, double check with this: http://contentdocs.installernet.com/...icle/10922.pdf Installation guide for a 2000 GP.
If all of that is correct, also make sure the turn on lead you're connecting it to truely has voltage coming through it when your car is in ACC or ON.
I will give it another shot after i check for voltage. Thanks for that tip!
