LOL..you thought you were pushing the subs too hard so you dropped the impedance of the sub? That sub is only capable of being wired at 8 ohm or 2ohm. I would go back to 8 ohm. If your amp is shutting down, its probably drawing too much current. Or its overheating. It sounds like you're pulling too much current through the wire and its popping your fuse. Most 4 gauge wires can handle up to a 125A fuse . (Depends on how well the wire is built) If your fuse is burning and not blowing, you should look into getting a better fuse and holder. Like an ANL fuse and holder. For the frequency on the amp, I'd set it for 80hz or below.
what do you meen the sub is only capable of being wired to 2 ohm or 8 ohm? no its not its capable of 2 ohm and 4 ohm and im running 2 of them btw
Edit: look at the post for the subs there is a wiring diagram for 2 subs with 2 channel amp those are the ones i tried
