Thread: post up your audio equipment
Page 25 of 36 FirstFirst ... 15232425262735 ... LastLast
Results 481 to 500 of 707
  1. #481 Re: post up your audio equipment
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    old video, finally uploaded tho
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Quote Originally Posted by 1LoudGrandPrix View Post
    Nice nice man. How did you get it so loud with trunk open? Mine sounds hollow with the trunk open, still loud but like without compression
  3. #483 Re: post up your audio equipment
    Cedar Rapids, IA
    bet yours isn't sealed off, or near as well as mine
    Mar 2012
    Minneapolis MN
    I have the Polk Audio db212-2. It's a ported box.
    Not my car but it's the box that I have.
  5. #485 Re: post up your audio equipment
    Sep 2012
    Cedar Rapids, Iowa
    Just a new deck nothing too fancy. But it's the first one I put in.
  6. #486 Re: post up your audio equipment
    Yoga city
    curent re audio se 12's, re audio dts 1500.1, stock nav
  7. #487 Re: post up your audio equipment
    GT Level Member douger's Avatar
    Aug 2012
    Fort Wayne
    I've just finished putting a Pioneer AVH-P2400BT in. I had a XM receiver from my previous ride, and added HD radio to it. (If I'd done just a little more homework, I would have gotten the next level Pioneer that would have had the HD radio built it.) It all pours into the OEM Monsoon amp system.
    I've got the Bluetooth mic sitting under the instrument cluster temporarily. I can't make up my mind whether to mount it in the overhead lamp or hack into the On-Star and use its mic.
    I'm also looking into getting an XM antenna off a later G6...which mounts on the trunk lid...so that I don't have to worry about the magnetic base of the Pioneer antenna sliding all over the place.
    I've got two problems I still need to clear up. I'm getting RAP feedback into the engine's run circuitry. The engine will run with the key off until I open the door. I'm thinking that the GM-01 adapter I got, which has a hookup for the VSS and backup circuits might be back feeding the PCM through the VSS circuit. Since I'm really not planning on GPS for this, the next time I pull the radio, I've gotta hack into that nicely wrapped harness and cut that.
    The other issue is some very occasional popping and scratching through the Monsoon amp that I'll hear with the volume of the head unit turned all the way down. I'm going to give ground loop isolators a whirl...but I'm not real hopeful. I've swapped amps and still have the problem, though one amp is a bit better than the other.
  8. #488 Re: post up your audio equipment
    Sep 2012
    Cincinnati
    2 18s on 12k
  9. #489 Re: post up your audio equipment
    Yoga city
    hairtricks lol i can lift dreads in my back seat on 12's lol
  10. #490 Re: post up your audio equipment
    GT Level Member Adidasdude1989's Avatar
    Jan 2012
    Sturgis, MI
    Im currently still upgrading my system little by little so thats my only project in progress, not sure if these specs was necessary but i posted them anyway.
    AMP:
    • 1 Ohm Stable Class D Mono Block Amplifier
    • Low Level Input and Output
    • Frequency Response: 15Hz ~ 270Hz
    • Input Level: 6V~0.2V
    • Variable Subsonic: 10Hz ~ 50Hz
    • Variable Low Pass Filter: 35Hz ~ 250Hz
    • Variable Bass Boost: 0db ~ 9db
    • S/N Ratio: >85
    • THD: 0.1%
    • Remote Gain Controller
    • Two Amplifiers Linkable Connector and Selector
    • Fuse Rating: 60Amps, Linked Fuse Rating: 120 Amps
    • 1500 Watts Max
    • 800 Watts RMS
    • Dimensions (Inches)
    • Height: 2.18
    • Width: 9.13
    • Length: 11.81
    SUBS:
    • RMS 400W
    • MAX 600W
    • Impedence (Ohm) 2x4
    • Rdc (Ohm) 1.7
    • Levc mH 1.346
    • Fo Hz 36.2
    • Sd msqM 47.14
    • BL TM 8.624
    • Qms 3.617
    • Qes 0.786
    • Qts 0.645
    • n% 0.222
    • SPL dB 87.5
    • Vas L 37.1
    • Cms uM/N 111.1
    • Mms g 164.8
    • VC Inch 2
    • Mgnt oz 80
    • Xmax ±MM 11
    • F.Range Hz <800
    • MM 150
    • Inch 5.9
    • SPK DISP. L 3.583
    Miles: 170-XXX
    Engine: 3.8L V6
    http://youtube.com/KBsVlog
  11. #491 Re: post up your audio equipment
    SE Level Member jspang23's Avatar
    Sep 2012
    Peru,Illinois
    New to forum hope to post pics soon Once I figure out how but I have a kenwood ddx419 alpine type-r 6 1/2 components all around with custom pods for rear. Two type- r 12 dvc 2 ohm subs ported box. Fosgate amps 400.4 & 800.2. Just purchased additional 800.2 along with 5 farad capacitor which I havent installed yet.
  12. #492 Re: post up your audio equipment
    GT Level Member chrishova's Avatar
    Norfolk, Virginia, United States
    Nice job BFF Larry!!! What 18''s?!?! I'm going to forget the "all in the trunk" single sub setup and trade-in my SMD for 2 18''s or 4 15''s!!! What subs are you running?!?
    I cut out the 6'' port and doing an 8''... lil better numbers....
  13. #493 Re: post up your audio equipment
    Sep 2012
    Peru,Illinois
    how do you post pics
    Do not use a Cap!!! It is easy to put a HO DR44 alt on! They usually ate on Tahoes and are very common and easily do 300a
    Check my sig or my other thread here on HO alt in a Grand Prix
    Sent from my Galaxy
  15. #495 Re: post up your audio equipment
    Sep 2012
    Peru,Illinois
    speaker box.JPGamps.JPGstereo.JPGStill a work in progress hope to get it finished this winter
  16. #496 Re: post up your audio equipment
    Mar 2012
    Mississippi
    How did you make the Grand Prix GT thing light up? I like that!
  17. #497 Re: post up your audio equipment
    Sep 2011
    Copperas Cove, TEXAS
    Quote Originally Posted by stuntsiderida100 View Post
    The light up "GP GT" radio mount is from Humount. Here is the link Grand Prix 1992-2003 - $65.00 : Humount, Quality Mounting Brackets
    GT Level Member maverickdog8's Avatar
    Bettendorf, Iowa
    For some reason I can't post my pics off my phone. Will have to later. Currently have my prix set up for 2 18s walled in the back seat off 2 shok industries 5kws. I will be running team shok 18s this next spring. Ill figure out how to post some pics up as soon as I get home. I have a build log if you hunt through my started threads though until then.
  19. #499 Re: post up your audio equipment
    Yoga city
    your gonna have to use photobucket or an alike website to post pics here, cant wait to see
    Quote Originally Posted by maverickdog8 View Post
  20. #500 Re: post up your audio equipment
    Bettendorf, Iowa
  1. 1st post lol
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2010, 10:56 AM
  2. Birthday Post
    By GTPluv in forum Off Topic Discussion
    Last Post: 01-04-2008, 04:30 PM
  3. First post! HUD.
    By gmboy in forum Visual/Body Modifications
    Last Post: 12-13-2007, 08:44 PM
