Well that's the thing, it doesnt say if its 600W rms at 1ohm or at 4ohm.
EDIT: Scratch that, I forgot we are talking about subs, not amps. Its gonna require 600w rms no matter what impedance you run it at. I would get the amp you want, then match the sub to that amp.
I don't really want to explain how or why but if you find a GT series 5 channel amplifier(and I found plenty last night, just not the GT-50...GT-5750(sp?) came up though) then you'll be just fine. Again, if you want to understand more about power etc. then google is your friend. But I can promise you that 300watts vs. 600 watts isnt' the end of the world and only equates to ~3db increase which tests have shown is the bare minimum in perceived change of sound output.
fyi... Mono Amplifiers
That should start some head scratching He use to rate his huge-normous SPL amp at 15 watts. Don't forget about the "under-rated" 50watt amps of the 90's winning SPL competitions Ever seen 150+ db's w/500watts? Well 300 watts probably wouldn't hurt the output of that setup too much either ;P
edit: 1ohm = sad face
