So I see. I was taking a look at that sub you picked out. Looks like its rated at 500w RMS. Doesn't mean you have to be there, but somewhere in the upper half of that range 300w+ would be good. Secondly, with that DVC of 2-ohms you can either wire it at 1ohm or 4, this is good and bad. If you can find an amplifier thats stable at 1 ohm, this is great. However, most are not therefor wiring at 4ohms is going to half the power to your speaker than wiring at 2 ohms (most amplifiers are stable at 2-ohms).
Long story short. If you can find a 1 ohm stable amplifier, this is the right speaker. If you can't, buy the P3D4-12 woofer so you can wire it at 2 ohms.
