Thread: picking the right amp?
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 105
  1. #1 picking the right amp?
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    alright guys, so i have two 12" subs. they are in two single boxes. so wiring them in parallel can be done but it would be sort of difficult IMO but maybe not.
    my friend gave me these subs for free, so dont tell me theyre crappy or whatever because you cant beat free. especially at the age of 16.
    sub 1
    Pioneer TS-W301R 12" 4-ohm subwoofer at Crutchfield.com
    sub 2
    Pioneer TS-W302R 12" 4-ohm component subwoofer at Crutchfield.com
    both are SVC
    both are 50-150 RMS (800 peak)
    both are 4ohm
    so what amp do i need?
    From what i understand...
    about a 300W amp is what is preffered as far as wattage
    2 channels would be easiest as far as wiring because theyre each in a single box
    the amp ive been looking at was this one
    Orion - Cobalt Series 300W 2-Channel Amplifier with Variable Crossover - CO3002
    any advice or anything is greatly appreciated! i dont want to ruin any of my stuff and want to get the most out of it, also money is an issue. thanks guys!
  2. #2 Re: picking the right amp?
    Houston
    Wiring them parallel will be easy seeing they're both SVC. Just wire them as you normally would and bridge them at the amp. Those are basically the same subs, except one is a series newer. Im not sure about the amp, because there is very limited details about it. Is the amp 300 x 2 or 150 x 2? Is that RMS or Peak? And at what load are those numbers 2 ohm or 4 ohm? I'd point you toward some amps, but Im not sure what your budget is.
  3. #3 Re: picking the right amp?
    Nov 2011
    Decatur
    I don't really have a "budget" I'm just trying to find what will work the best for the cheapest price. my friend also said he would sell me his Rockford fosgate amp for $50 I think he said it's 300 watts but I have no idea which one it is.. I'm trying to get all the details
  4. #4 Re: picking the right amp?
    Nov 2011
    Decatur
    I found the amp on a different website (I think lol) PROVANTAGE: Directed Electronic Inc CO3002 Directed Electronics 300 W 2 CH Amp with x Over got more details there
    or here
    http://www.sonicelectronix.com/item_...lt-CO3002.html
    or here
    http://www.orioncaraudio.com/Product...?ProductID=569
    after looking at these specs it seems I could probably get a better one since it's only puttin out 55 watts at 4 ohm and my subs take up to 150 right?
  5. #5 Re: picking the right amp?
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    So you have two subwoofers that both have a single voice coil rated for up to 150 watts RMS each at 4 ohms, so when you wire them in parallel you will half the impedance to 2 ohms. So you are looking for one of two amplifiers. Either an Single channel amplifier or two channel amplifier bridged (combining both channels) which has a power output of around 300w RMS at 2 ohms (IMPORTANT) OR a 2 channel amplifier (not bridged, 1 channel for 1 woofer) which has a power output of around 150 Watts at 4 ohms.
    All three configurations would be safe for both the amplifier and the subwoofers.
    As for the amplifier you have posted, although it would work, it may be under powering the subwoofers by only providing 60 watts at 4 ohms for each channel (and woofer).
    Let me know if you have any more questions!
    Infinity all around.
  6. #6 Re: picking the right amp?
    Nov 2009
    illinois
    this would be a good amp for ~100$. its cheap but its built pretty good compared to other cheap amps. Wire your subs parallel for 2ohm load. Youll have ~200 watts to each sub. Leave bass boost off and keep gains on low side and you should be fine. Its better to overpower than underpower anyways. You shouldnt have to worry about a clipped signal at all this way either. Most tend to find a cheap amp and overdrive it creating clipped signals that will destroy subs.
    MB Quart FX1.400 (fx1400) 400W RMS, 1-Channel Monoblock Formula
  7. #7 Re: picking the right amp?
    Nov 2011
    Decatur
    wouldnt it be easier to just get a 2ch amp and wire them like this?
  8. #8 Re: picking the right amp?
    THe picture you have is the correct way to setup an 2-channel amplifier with two 4 ohm subwoofers. Although this is simple, you can achieve more power by hooking up both subwoofers in parallel to achieve a 2-ohm load to a mono- amplifier. Think of ohms as being resistance, the higher the amount, the harder the electricity has to work to achieve the same power. If you wire the subwoofers in parallel, you can have this resistance to 2-ohms. Not only this but for most mono amplifiers, they have two speaker outputs, so hooking them subwoofers up would be no different then your picture describes, except you would be getting more power. Long story short is if you have a 2-channel amplifier, this is the correct way to hook it up but, the better setup is a mono amp with both subwoofers in parallel. Theoretically, half the resistance, twice the power.
  9. #9 Re: picking the right amp?
    Nov 2011
    Decatur
    so the preferred way would be to get a mono amp?
  10. #10 Re: picking the right amp?
    Feb 2009
    Virginia
    I'd say this is a good amplifier...I wouldn't mess with wiring independently unless you plan on using a stereo signal. If you're using a mono signal then just run the subs off one channel.
    MB Quart ONX1.1500D - ONYX Class D Monoblock Car Amplifier/Amp
    11 is louder than 10!
  11. #11 Re: picking the right amp?
    Nov 2009
    illinois
    IMO that amp I800 posted is way to much of an amp for what you need. Id still take a look at the amp i linked however. MB Quart makes decent amps.
  12. #12 Re: picking the right amp?
    Houston
    Quote Originally Posted by 2dee11 View Post
    It doesnt have to be a mono-block, you can achieve the same thing with a two channel by just wiring both subs across both channels (bridge)
    EDIT** This is actually the wrong picture, this is showing them wired in series.
  13. #13 Re: picking the right amp?
    Yup, this is the third option I presented. This however my be difficult because most 2 channel amplifiers are not 2ohm stable when they are bridged. So this may be difficult to find.
  14. #14 Re: picking the right amp?
    Nov 2011
    Decatur
    those both are 2 ohm subs though? mine are 4 ohms each
  15. #15 Re: picking the right amp?
    Topeka, KS
    When you wire them in Parallel it knocks the ohms down to 2ohm. That's why they say you want a 2ohm stable amp.
  16. #16 Re: picking the right amp?
    You are right. The picture is incorrect for your setup. Your amp would see 2ohms bridged.
  17. #17 Re: picking the right amp?
    Nov 2011
    Decatur
    so i am looking at some mono amps now and all the ratings i want to look at are @2ohms right? so i want one that is 100-300w x 1 @ 2ohms
    and the diagram would look like this right?
    OH and any amps from best buy would be preferrable cause my bestfriend can use his employee discount! lol
  18. #18 Re: picking the right amp?
    Yup. That is completely right. I also think someone else mentioned that you should be on the higher side of what your subwoofers RMS rating is, rather than the lower. That and you can even go a little over if you need to without damaging them. Also, one thing is that when you actually do the wiring itself, MANY mono-amplifiers have two sets of speaker terminals. These are there for your convenience and you should most certainly feel free to take advantage of them because they wire up the speakers the same way your picture describes.
  19. #19 Re: picking the right amp?
    Nov 2011
    Decatur
    what about this amp?
    Renegade REN-850S - Custom Radio Buffalo
    from bestbuy
    Renegade - REN 850 S Car Amplifier - 225 W @ 4 Ohm - 1 Channel - REN 850 S
    now that i have an idea of what i'm looking for i just dont know about the quality
  20. #20 Re: picking the right amp?
    That amp is rated 225W at 4ohms. It didn't mention anything about running at 2 ohms so I can't say much about it's power delivery. May I make a recommendation for an amplifier I have worked with and enjoy. Its an infinity REF1300A and can be found for less than $150 online. Its a great amplifier at a great price and would work with your two subwoofers wonderfully.
  1. Picking up a GTP
    By E90 87SS GTP in forum Introductions/Noob Questions
    Last Post: 09-26-2009, 05:22 PM
  2. Need Help Picking Car!!
    By cue244 in forum Off Topic Discussion
    Last Post: 07-03-2009, 06:14 AM
  3. Need help picking a project car : /
    By gdbyrd in forum Off Topic Discussion
    Last Post: 05-02-2009, 05:13 PM
  4. Picking a car
    By robahr24 in forum General Tech Discussion
    Last Post: 01-04-2009, 03:05 PM
  5. Been picking on new gen Mustang GT's
    By DesQ27 in forum Track Sessions and Kills
    Last Post: 10-14-2008, 11:52 PM
