Quote Originally Posted by archemedes View Post
Keep in mind on most aftermarket high output alternators that they don't charge at idle (as in they shut down) I used to compete, and we had to bring the idle up to 1200 rpm's to get any output from them
Whoever told you that, or built your alternators didn't know what they were doing. Almost all aftermarket h/o alts put out at least stock numbers at idle, some are slightly lower than stock and some are higher than stock, but they do at least charge. The reason why you raised the "idle" to 1200 is because that is usually right around cruising rpm, and h/o alts are designed to put out the big power at cruising speed.
Look at these eBay Store - Alternator: High amp: iraggi, factory replacement, this guy is who 50% of pro sound off competitors use currently, and I used him when I was competing with my silverado's in the pro unlimited class the past 8 years.
Sorry guys no pics of that because 1 it wasn't pretty and 2 the box at the time was pretty much a classified design.
