Thread: Aftermarket headunit install on BOSE system??
Results 1 to 20 of 28
Threaded View
  1. #12
    St. Louis Mo.
    Quote Originally Posted by s1795so2 View Post
    I am sorry, I should have revised my statement above to bose will work 90% of the time w/ the 20 dollar harness, I forgot about way #2, but also I was troubleshooting why my guages wasn't working in my car at the same time I was on here earlier.
    There is 3 ways to replace the stock w/ an aftermarket radio that I know of w/ onstar/bose/monsoon.
    2)the part number from metra is 70-2003, it is about 20 dollars and it is a harness for just the radio plug, all you need to do is hook up the power antenna or sometimes the remote turn on wire (both essentially do the same thing, just one wont work sometimes and the other will) to the factory amp turn on wire. *You lose onstar and chimes this way though* If people need the wiring colors I can supply this, it just might take me a day, because I know a lot of wiring off hand, but not everyones.
    3)The other way is metra part number gmos-04, and is actually one of the coolest wiring harnesses out there, because it is adaptable to pretty much any grand prix from 00 up w/ onstar and monsoon/bose systems. But anyway it is a straight harness that is solely plug in and go. The only downside is that its over 100, I am pretty sure its about 149 bux. Everything stays functional with this.
    James #3 would be your best bet.
    -steven-
    Thanks for the reply Steve.
    I am not running my onstar on my car, Bill and I removed the antenna when we tinted my windows. So losing my onstar is no big deal. So would the #2 option above work for me??
    My Bose speakers are still sounding great, all I really need is a better headunit.
    I did find the Metra gmos-04 plug unit on Crutchfield for $99 bucks.
    GM Factory Integration Adapter General Motors Class II data bus interfaceRetains ONSTAR system, factory door chime, and Bose system with aftermarket radio at Crutchfield.com
    That price is not bad, but as I said before, my onstar is not even working anyways. So I should be able to go with the #2 option instead.
    And I found a really good PDF document from the Metra Website on their various wiring hookups.
    http://www.metraonline.com/downloads...NST70-2003.pdf
    Just thought I would share this to the community
    Let me know!
    Many thanks!!
    Last edited by GeddyLee; 01-03-2008 at 08:28 AM. Reason: Edited to include links I found.
    James Shafer
    St. Louis MO
  1. Shift Kit[*]
    By Trannyman95 in forum How To Write-Ups/Tech Tips
    Last Post: 06-03-2012, 01:40 PM
  2. Short Stack Intercooler [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-30-2012, 04:20 PM
  3. rear window regulator/motor install write up
    By ExpyGator in forum General Tech Discussion
    Last Post: 11-17-2009, 12:52 PM
  4. Phenolic Throttle Body Spacer [*]
    Last Post: 09-27-2008, 03:21 PM
  5. Bose?
    By flynn in forum Audio, Security & Visual Electronics
    Last Post: 08-16-2008, 04:24 PM
