Thread: Anybody else have this problem?
Results 1 to 4 of 4
  1. #1 Anybody else have this problem?
    SE Level Member tgarison's Avatar
    Abilene, Tx
    Hey forum,
    I bought a used JVC in dash cd player today from a local pawn shop. I get home and take out the old cd player and disconnect all the wiring I then wire up the used one that i just bought i turn it on and it works great, so i turn it off and put it in the dash I try to turn it back on and its completely dead nothing on it works. I check the fuse's and find the Radio Batt. fuse under the hood blew, I found the wire fixed that problem and replaced the fuse, the damn thing still wont work! I also have a problem with the power window's in that none of them will work I rolled them down to work in comfort and they wont roll back up its like they are not getting any power I tried replacing the 25 amp "circuit breaker" with a 25 amp fuse and that did nothing. I am really stumped and need help with this. The car is a 99 Pontiac Grand Prix GT if that helps.
    Thanks in advance,
    Tgarison
    If you want to find out more about me or my GPGT click the link below it takes you to my youtube channel.
    http://www.youtube.com/user/grandprixgt1999
  2. #2 Re: Anybody else have this problem?
    Probably blew the igntion and battery fuses. Check for another.
    BTW, what was the issue wtih the wire, got pinched?
  3. #3 Re: Anybody else have this problem?
    Abilene, Tx
    Thanks for responding billboost but i figured out how to fix everything before i saw your reply, as far as the wire goes the electric tape I wrapped around it came off and it shorted out on a piece of metal in the dash. The window motor issue was I pulled a fuse while trying to find the bad fuse that I thought had no bearing at all on the power windows, the fuse panel has it labeled "RAP" I pulled that and all the window motor's went dead. I have it all back up and working, now just to tune the stereo. Thanks for all the help.
  4. #4 Re: Anybody else have this problem?
    GTP Level Member simbah's Avatar
    Lala land
    You had tape wrapped around the wire and it came off, Doesn't that tell you that maybe there is a better way to make a connection of two wires. one that is a little bit more secure, like aleast a wire nut then some tape. The preferred method is solder and heat shrink, but a crimp on connector is also good, much better option over just tape.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  1. next problem
    By nicks98gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-13-2011, 10:51 PM
  2. Anyone ever have this problem??
    By Peirce1970 in forum General Tech Discussion
    Last Post: 06-10-2011, 05:02 PM
  3. Another ABS problem...
    By SuperCharged0nE in forum Brakes/Suspension/Chassis
    Last Post: 03-05-2010, 12:55 PM
  4. DIC problem
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2008, 04:41 PM
  5. well now its a problem...
    By the1euge in forum General Tech Discussion
    Last Post: 10-26-2008, 01:43 AM
