Thread: Performance shift flicker
Results 1 to 7 of 7
  1. #1 Performance shift flicker
    Dec 2011
    Moraine, Ohio, United States
    Hey guys, I was wondering if you could help me out. Finally got my car looking pretty nice. Just need a set of rims and it'll be gorgeous! But! On the Driver info center the "performance shift" flickers.
    If I click it on, it stays on, but if its off it flickers. Any suggestions? I have replaced the stock head unit.
    BoostKillinIt.
  2. #2 Re: Performance shift flicker
    loose connection?
    Just leave it on, thats what I do.
  3. #3 Re: Performance shift flicker
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    at least yours show up... i cant see it... but when i gas it i know its engaged
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  4. #4 Re: Performance shift flicker
    Dec 2011
    Hmm.. alright. Does anyone know how to get behind the DIC?
    BoostKillinIt.
  5. #5 Re: Performance shift flicker
    Yes, First you use the miniturizor from the movie Innerspace and then you are small enough. Or maybe it's better to get Rick Moranis to shrink you. Either way...get smaller and then you can walk around behind the dash.
    Or you can just pull the dash panel and remove it to take a look. Most likely there's a wire (the ground at the shifter very likely) that has a nick in it and it's occasionally grounding out and causing the issue.
  6. #6 Re: Performance shift flicker
    Dec 2011
    Ground*
    BoostKillinIt.
  7. #7 Re: Performance shift flicker
    Dec 2011
    Lol alright. So could i take my shifter apart and try and fix the fround?
    BoostKillinIt.
  1. Performance shift
    By zakk in forum General Tech Discussion
    Last Post: 11-13-2011, 05:42 PM
  2. Performance shift on used DIC
    By Joe in forum General Tech Discussion
    Last Post: 07-02-2009, 05:08 PM
  3. Performance shift
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 04-12-2009, 11:03 PM
  4. Performance Shift?????
    By kingbrentdwyer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-13-2009, 01:23 AM
  5. performance shift WTH?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 07-08-2008, 09:44 PM
