Thread: DIC Problems
Results 1 to 6 of 6
  1. #1 DIC Problems
    Jan 2012
    SCS, MI
    I did the Analog to Digital DIC conversion in my 2001 GP. It functioned for a bit, now the display is blank. I checked the fuses and bulbs and all are in working order. Suggestions?
  2. #2 Re: DIC Problems
    Out West
    viagra
    Whine with your Cheese?
    Ohio
    Gt or gtp?
    Sent from my DROIDX using Tapatalk
  4. #4 Re: DIC Problems
    Jan 2012
    SCS, MI
    Quote Originally Posted by 99pgpgt View Post
    Gt or gtp?
    It is a GT.
  5. #5 Re: DIC Problems
    Bunnell, FL
    pics of the dic and wiring?
    you sure you hook everything up correctly, soldered and not used cheap connectors? and if you did, heat shrink or electrical tape the **** out of it?
    I'm a Sex Offender
  6. #6 Re: DIC Problems
    Sep 2012
    camden,sc
    im doing the same conversion to my 99 right now and im stuck on a few extra wires with no where to put them,oh yea also my car has the right trac control button or unit. behind the speedo im hooked up good and also the information wire by your knees at the bottom.my problem is they say behind the hvac theres a 12 pin connector to splice into ,its not there so where do i place the battery wire and the aux wire,stumped if you can call that would be great,rob 803 420 7770 frustrated thanx
  1. ABS Problems
    By Logan541 in forum Brakes/Suspension/Chassis
    Last Post: 12-12-2011, 05:49 AM
  2. Problems with the GTP
    By DaL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2010, 02:21 PM
  3. HID problems AGAIN
    By lilbear6889 in forum Visual/Body Modifications
    Last Post: 07-26-2010, 07:12 AM
  4. New guy with a few car problems......lol
    By jigwynn in forum Introductions/Noob Questions
    Last Post: 04-24-2010, 10:58 PM
  5. a/c problems
    By ddyke2000 in forum General Tech Discussion
    Last Post: 06-23-2009, 06:15 PM
