Thread: Firewall?
Results 1 to 11 of 11
  1. #1 Firewall?
    Sep 2011
    Springfield, MO
    I'm trying to find a way to get through the firewall without drilling and installing a new grommet. I have an 04 GTP and all knowledge from other peoples previous installations would be great.
    Thanks,
    Evan
  2. #2 Re: Firewall?
    Pennsylvania
    What are you trying to put through it? Vacuum hose? Power cable? Just put a hole in a pre-existing gromet.
  3. #3 Re: Firewall?
    you mean bulkhead,
    its not firewall anymore due to legal reasons
    SMGPFC Member #10
  4. #4 Re: Firewall?
    Sep 2011
    Springfield, MO
    oh sorry it's for a power cable to the subs I'm installing.
  5. #5 Re: Firewall?
    Chilliwack BC
    pull the carpet back on the passenger side floor. there is some insulation underneath you pull up. and there is a hole there to feed through. had to put my car in the air to get at it once it was through. but worked good for me
  6. #6 Re: Firewall?
    Pennsylvania
    Quote Originally Posted by Couch View Post
    Nah, just lay on top of the engine and reach for it.
  7. #7 Re: Firewall?
    Chilliwack BC
    Quote Originally Posted by SlowNA06 View Post
    ya i was lazy. and had a hoist to use.
  8. #8 Re: Firewall?
    Aug 2011
    Iowa
    i was wondering the same thing! i found the rubber gromet on the passenger side but i cant get the damn gromet out! i even tried drilling a hole in it to snake the wire through but no luck..any ideas on how to get 0 gauge through that thing?
  9. #9 Re: Firewall?
    SE Level Member habeba86's Avatar
    Elmwood/Peoria Ill
    Quote Originally Posted by AndrewBR98 View Post
    It is a pain, even as an installer it still takes me a bit to get it out and cram my hand back there. Let the car sit for a while if uve drove it, bcuz that metal u rub on is HOT and hurts
    10 Z1000
    00 gtp..few goodies
    97 XJ
    98 T/A cammed/stalled/spray *sold*
  10. #10 Re: Firewall?
    Pennsylvania
    Just popped it out by hand. Might have used a flathead screwdriver. Seems to me like you're making this a bit more complicated than it needs to be. you spend 2 minutes passing the wire from inside the car to the engine bay and 10 minutes trying to snake your hand down past the engine to grab it.
  11. #11 Re: Firewall?
    GTP Level Member AjL227's Avatar
    IL
    There is a grommet on the driver side past the carpet as well. I've fed through a power wire for an amplifier, wiring harness for a boost gauge, fuel pressure gauge, and a wideband, all without drilling or modifying anything. So, I don't think you should have any problem.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  1. Wiring through Firewall
    By Timmi in forum General Tech Discussion
    Last Post: 03-03-2010, 09:05 PM
  2. Where to run power wire through firewall
    By Bueller in forum Audio, Security & Visual Electronics
    Last Post: 12-05-2009, 11:59 PM
  3. Firewall Pass through
    By Luda in forum Audio, Security & Visual Electronics
    Last Post: 06-16-2009, 05:06 PM
  4. firewall holes?
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 03-07-2009, 12:22 AM
  5. Removing firewall grommet???
    By IndeedSS in forum General Tech Discussion
    Last Post: 09-14-2008, 04:41 PM
