Thread: Will I need Dynamat?
Results 1 to 11 of 11
  1. #1 Will I need Dynamat?
    May 2011
    Mi
    I have 2 12" CVX's and i was told i need put down dynamat or some sound deadening material or they will rattle my spoiler off and break ****. I used to have them in a tahoe before i got the GP and there were loud as F**k but i wasnt too worried about breaking anything in the tahoe. So is dynamat really necessary?
  2. #2 Re: Will I need Dynamat?
    Florida
    Nope. You can pound as hard as you want to as long as you dont mind rattles.
    Stick a piece of cardboard/foam/sound deadener behind the license plate, and Put some foam under the spoiler. (You can remove the spoiler via popping the trunk, and removing the 10mm bolts. Takes about 2minutes)
    That should kill those rattles.
  3. #3 Re: Will I need Dynamat?
    May 2011
    Mi
    Alright I'll have to try it. Thanks
  4. #4 Re: Will I need Dynamat?
    Never Never Land
    don't need it if you dont mind the rattling but it helps a lot. I did my doors, rear panels, and trunk so far. I don't have my system in yet and it won't go in until the car has an alarm. I've noticed a difference in how loud it is inside the car which is surpsing because I used a vibration dampener and not an actual sound deadener.
  5. #5 Re: Will I need Dynamat?
    May 2011
    Mi
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    What did you use?
  6. #6 Re: Will I need Dynamat?
    Feb 2009
    Virginia
    They're actually the same
    Speakers = vibrations. Vibrations = noise. Stop those vibrations and you stop the music(noise)
    11 is louder than 10!
  7. #7 Re: Will I need Dynamat?
    Never Never Land
    Second Skin Damplifier Pro. It's about half the price of Dynamat Extreme and the material specifcations are pretty close. The difference between SS and Dynamat are little to none from what i've read so I didn't see any reason to pay twice as much for basically the same stuff.
  8. #8 Re: Will I need Dynamat?
    Florida
    ^^ Second Skin is awesome stuff.. IMO just get the liquid, its so much easier to lay than the peel and stick.
  9. #9 Re: Will I need Dynamat?
    May 2011
    Mi
    Alright thanks guys
  10. #10 Re: Will I need Dynamat?
    Never Never Land
    They're not the same. A vibration dampener acts AS a sound deadener because it stops the vibration which creates new noises.
    Vibration Dampener- Damplifier Pro - Automotive Sound Deadener CLD Vibration damping mat - See what all the fuss is about
    Sound/noise Dampener- Luxury Liner - Acoustic Noise Barrier and Insulation Barrier
  11. #11 Re: Will I need Dynamat?
    Feb 2009
    Virginia
    marketing.
    I will say that you can use MLV for another purpose too but I don't feel like talking about that. You're indirectly pulling attention to it with your links
  1. Recommendations for Dynamat alternatives?
    By nik12937 in forum Audio, Security & Visual Electronics
    Last Post: 01-17-2011, 08:13 AM
  2. Dynamat VS Carpet padding.
    By RichCresci in forum Audio, Security & Visual Electronics
    Last Post: 01-11-2009, 05:04 PM
