Thread: Aftermarket Head Unit Wiring Help?
Results 1 to 6 of 6
  1. #1 Aftermarket Head Unit Wiring Help?
    Seabrook
    -2006 GP, Monsoon System
    - I'm not asking about what components I need.
    Yellow (from car out) to Yellow (radio in) for power.
    ALL RCA's are hooked up
    I'm confused on where the blue/white wire goes, and even confused on where the red wire (Ignition) goes.
    I have power to the head unit, but no sound output. I know my explanation isn't the best but I really suck with wiring. I've installed two head units before on other makes and models but this is BY FAR the most over complicated and so fat it's winning .
    Any comments or insight would be appreciated.
  2. #2 Re: Aftermarket Head Unit Wiring Help?
    GTP Level Member simbah's Avatar
    Lala land
    What components do you have? HU ADapter?
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  3. #3 Re: Aftermarket Head Unit Wiring Help?
    Seabrook
    Gmos04
  4. #4 Re: Aftermarket Head Unit Wiring Help?
    Lala land
    red wire of adapter goes to radio ignition wire most likely also red, blue/white wire goes to amp turn on wire from radio make sure it is not power antenna lead most likely also blue wire
  5. #5 Re: Aftermarket Head Unit Wiring Help?
    Seabrook
    well i went with a normal harness, not the gmos04. i gave up, so i took it to a shop around here, they tried for an hour and couldnt figure it out. thanks for the help though
  6. #6 Re: Aftermarket Head Unit Wiring Help?
    SE Level Member Peirce1970's Avatar
    Myrtle beach, S.C.
    I had the same problem when I bought my gtp. After playing around with it for countless hours I took it to a shop. They determined the monsoon amp was bad and bypassed it.
  1. Aftermarket Head Unit 2005 GP
    By goliath500 in forum Audio, Security & Visual Electronics
    Last Post: 05-05-2011, 07:42 PM
  2. Any aftermarket Head Unit Pics for 04+?
    By nickbuol in forum Audio, Security & Visual Electronics
    Last Post: 12-10-2010, 09:56 AM
  3. aftermarket head unit radio reception problem
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 06-22-2009, 10:55 PM
  4. SW-controls to aftermarket head unit?
    By GreenNirvana101 in forum Audio, Security & Visual Electronics
    Last Post: 04-29-2008, 09:14 AM
