Thread: where to put amp?
Results 1 to 15 of 15
  1. #1 Re: where to put amp?
    GTX Level Member Confusingboat's Avatar
    Minnesota
    Where is this amp rack thread? I was planning on doing the same thing once I need more than one amp. For now I just mounted it on the side of the trunk like so:
    Yeah yeah yeah I know it'll fall off eventually, but I'll have moved it before then.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  2. #2 Re: where to put amp?
    screw it to the under side of the rear deck like under the 3rd brake light.
  3. #3 Re: where to put amp?
    Minnesota
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    The 3rd brake light is on the spoiler on 04+. And I've read not to mount amps upside down under the deck because they retain the heat a lot more.
    2015 Evo MR
  4. #4 Re: where to put amp?
    oh yeah about the 3rd brake light and mounting it their will make no difference than sideways of flat air flow is what matters and if that was the case you could mount it upside down and take the cover off and not have to worry about something smashing it or sitting on it
  5. #5 Re: where to put amp?
    Apr 2011
    Ohio
    the thread is on the third page of this section of the forum. also is there any place to mount it under the seats or anything where that will just hide the amp completely?
  6. #6 Re: where to put amp?
    inside the 1/4 panels if you have a 2 door just take off the side panels next to the back seats, tho temp might be an issue if its not like a class AB amp. I def wouldnt stick a class D mono amp in their
  7. #7 Re: where to put amp?
    Apr 2011
    Ohio
    The car is a 4 door 04 so not sure about the whole two door and what not stuff.
  8. #8 Re: where to put amp?
    Pennsylvania
    Are you doing drugs?
    Just mount it upside down (or heck, rightside up if you're weird) on the bottom of the rear deck. Or screw it to the skinny rear seatback. Or screw it into the side of the trunk. Or mount it to the trunklid and work on arm strength. These are your only options; there are no others. Any ideas you may have beyond these are ridiculous and will not work.
  9. #9 Re: where to put amp?
    Roseville, Michigan
    Quote Originally Posted by Confusingboat View Post
    Nice amp, I have the gta 504 4 channel amp running my interior speakers and an alpine MRP-M500 mono block amp running my flat kenwood 12 inch sub. I built an amprack that sits just beneath the rear deck.
amp, put
