oh yeah about the 3rd brake light and mounting it their will make no difference than sideways of flat air flow is what matters and if that was the case you could mount it upside down and take the cover off and not have to worry about something smashing it or sitting on it
the thread is on the third page of this section of the forum. also is there any place to mount it under the seats or anything where that will just hide the amp completely?
inside the 1/4 panels if you have a 2 door just take off the side panels next to the back seats, tho temp might be an issue if its not like a class AB amp. I def wouldnt stick a class D mono amp in their
The car is a 4 door 04 so not sure about the whole two door and what not stuff.
Are you doing drugs?
Just mount it upside down (or heck, rightside up if you're weird) on the bottom of the rear deck. Or screw it to the skinny rear seatback. Or screw it into the side of the trunk. Or mount it to the trunklid and work on arm strength. These are your only options; there are no others. Any ideas you may have beyond these are ridiculous and will not work.
