Thread: Front Speaker comparison.
Results 1 to 20 of 21
  1. #1 Re: Front Speaker comparison.
    Nov 2009
    illinois
    Quote Originally Posted by I800C0LLECT View Post
    I'm not trying to say you're wrong but I definitely think something was setup improperly. I've run "500+" watts on "50watt" speakers without problems. I don't want people to get the wrong impression about over inflated power numbers. It's very difficult to ruin speakers with "too much power" utilizing a clean signal. However, it's very easy to over-drive an amplifier and ruin a set of speakers with a clipped or distorted signal. Even improper gains can clip a signal. That's what typically ruins speakers that are playing off head unit power, over-driving(creating distortion) and a clipped signal(turning "LOUD" or bass knobs all the way up).
    Creating a sound wave in the bass region takes much more power than creating something in a higher octave such as 10khz to 20khz. Matter of fact, I highly doubt typical output to tweeters and mids exceeds 50watts. If you are certain your HP was 160hz you might want to run through your setup and verify that everything seems legit so you don't ruin the new speakers on accident
    FYI, changing your EQ effects your crossover as well.
    Gains are set fine. However my HU has loud feature that i leave on all the time. If i turn it off everything sounds like crap. Also with loud turned off, i literally have no bass from my sub. In order to get my sub to actually play bass as it should, I have to set my lows to +7 or more which is to much. I am 100% sure my HP is set to 160hz on my HU. Even though i have the loud feature on, i cannot hear distortion or clipping. Would my EQ settings be the culprit then?
    Loud Feature on.
    Low +1db
    Mid +2db
    High +1db
    I know its better to have the loud feature off, but everything seems way to flat to my liking and why i keep it on and for the bass problem i mentioned earlier.
  2. #2 Re: Front Speaker comparison.
    Feb 2009
    Virginia
    Quote Originally Posted by 2000GTGP View Post
    Loud Feature on.
    Low +1db
    Mid +2db
    High +1db
    Majority of people don't notice disortion in the bass region until it's above 20%. That includes clipped signals. When most hear clean bass, they turn the bass knob up.
    11 is louder than 10!
  3. #3 Re: Front Speaker comparison.
    Indianapolis
  1. Front Monsoon Speaker
    By MikeB91 in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2010, 02:33 PM
  2. Front Speaker Replacement
    By itfrg in forum Audio, Security & Visual Electronics
    Last Post: 05-02-2010, 06:42 PM
  3. Front Speaker Installation
    By SuperCharged0nE in forum Audio, Security & Visual Electronics
    Last Post: 12-11-2009, 10:28 AM
  4. Front Speaker Problems
    By Justin33 in forum Audio, Security & Visual Electronics
    Last Post: 08-21-2009, 06:46 PM
  5. Front Speaker Installation
    By justme in forum Audio, Security & Visual Electronics
    Last Post: 05-13-2009, 03:27 PM
