Thread: installing custom audio system for friend
Results 1 to 12 of 12
Threaded View
  1. #7 Re: installing custom audio system for friend
    Apr 2011
    ottawa
    Thanks for the quick reply. Guess thats a good spot if the alternator drops all the power. Heres some other questions. Firstly, I have to run a ground in the trunk for the amp. Is it possible to use one of the strut mounting bolts as a grounding spot? (combined with sanding to bare metal). And for the second question.. I don't know if you guys will be able to answer this because its about wiring the subs to the amp. The subs are Orion 12" Single Voice Coil 4 ohm and rated at 500 watt peak. The amp my friend has is 2 channel, meaning theres 2 outputs for speakers. Two of the terminals are bridged for mono use I guess. What I can't understand is if I have to wire each sub individually to the amp, or wire the subs in parallel or series to that bridged connection for mono output. Thanks
  1. installing a OEM Navigation system in 08 GXP
    By 2008gpxman in forum Audio, Security & Visual Electronics
    Last Post: 03-01-2013, 05:32 PM
  2. Installing a aftermarket deck on a Bose system.
    By Pontiacman76 in forum Audio, Security & Visual Electronics
    Last Post: 09-07-2011, 09:19 AM
  3. New to audio/saving for a new system
    By m1sterb0b in forum Audio, Security & Visual Electronics
    Last Post: 04-17-2010, 07:46 PM
  4. Installing system in 2005 GP for first time
    By stoner17971 in forum Audio, Security & Visual Electronics
    Last Post: 03-03-2009, 10:46 PM
  5. Don't know much about the audio scene, help me set up my system!!
    By copgtp in forum Audio, Security & Visual Electronics
    Last Post: 04-11-2008, 07:22 PM
