Thread: AUX Port...?
Results 1 to 20 of 20
  1. #1 AUX Port...?
    SE Level Member Jcal1120's Avatar
    Watertown, MN
    Is there a way to hook up an AUX port to a stock 6 disc stereo? 04+
  2. #2 Re: AUX Port...?
    Acworth, Georgia
    If you look at my post towards the end. I assume it will work for your year too but id wait for someone else to chime in
    http://www.grandprixforums.net/what-...d-2-40277.html
  3. #3 Re: AUX Port...?
    SE Level Member snodly's Avatar
    Jan 2009
    Warsaw, IN
    http://www.grandprixforums.net/how-a...-xm-21849.html
    This is the write up I used with my Monsoon system. Its pretty easy if you go to Radio Shack or a Fry's Electronics and get what you need.
    There is also the Pac-audio plug you can buy, but installing the aux into the XM line was cheaper and a lot more fun.
    Cheers!
    04 GP GTP Comp G - Paint mod= +50hp
    00 Ford Focus zx3, 95 VW Passat Vr6
    92 Chevy Silverado - 305 w/ 5-speed - rust mod
    80 Cadillac Eldorado Too Many Cars!!!
  4. #4 Re: AUX Port...?
    Watertown, MN
    Only issue, I don't believe the car is equipped with XM, or a monsoon system. It currently has the stock stereo that doesn't have the 6 disc. I have one on the way that I found on eBay that needs to be unlocked for my VIN to work.
    Will that cause an issue if it isn't set up with XM?
  5. #5 Re: AUX Port...?
    Jan 2009
    Warsaw, IN
    Are you getting a wiring harness with it? If so...
    On the 6-disk monsoon there will still be XM wiring you should be able to tap into.
  6. #6 Re: AUX Port...?
    Watertown, MN
    I am assuming no, I was told it was pretty much plug and play, except the issue of unlocking my VIN for it.
  7. #7 Re: AUX Port...?
    Jan 2009
    Warsaw, IN
    It should still have the XM option, I don't know anything about it being plug and play, but you should still be able to hook it up. You might have to look up the pin-out and see which pins use the XM lines and add the wires in on the plug.
  8. #8 Re: AUX Port...?
    Watertown, MN
    Which shouldn't be too difficult. Is there any other option to adding an AUX jack that you know of?
  9. #9 Re: AUX Port...?
    Jan 2009
    Warsaw, IN
    I believe Pac-audio.com sells an adapter, but i've never used it
    Adding the wires to the harness should be fairly easy, yes
  10. #10 Re: AUX Port...?
    GTX Level Member Confusingboat's Avatar
    Minnesota
    Quote Originally Posted by Jcal1120 View Post
    Other than getting a head unit with an aux port? No.
    EDIT: I lied lol. There are antenna adapters that allow you to switch between the antenna and an aux input -- they basically inject the sound into the antenna input. Same method as the PAC harness, just different point of injection. I personally use this one: http://www.crutchfield.com/p_469GM12...2.html?tp=1672 but I got it cheaper than that. I believe Crutchfield had it on sale at the time. Also, I don't have the Monsoon system so I'm not sure if it'll work with that particular head unit. You can always check on Crutchfield though.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  11. #11 Re: AUX Port...?
    Jan 2009
    Warsaw, IN
    Quote Originally Posted by Confusingboat View Post
    EDIT: I lied lol. There are antenna adapters that allow you to switch between the antenna and an aux input -- they basically inject the sound into the antenna input. Same method as the PAC harness, just different point of injection. I personally use this one: Precision Interface Electronics GM12-AUXv2 Connect a portable music player, satellite radio tuner, or DVD player to your factory GM receiver at Crutchfield.com but I got it cheaper than that. I believe Crutchfield had it on sale at the time. Also, I don't have the Monsoon system so I'm not sure if it'll work with that particular head unit. You can always check on Crutchfield though.
    Yea that adapter should work, but it says something about getting the radio programed to recognize the adapter.
  12. #12 Re: AUX Port...?
    Jan 2009
    Warsaw, IN
    do you have a link to the radio you bought?
  13. #13 Re: AUX Port...?
    Minnesota
    Quote Originally Posted by snodly View Post
    Me or him? Lol I have my stock single-disc head unit.
    Mine worked without any programming whatsoever. It just picked up the adapter as bands XM1 and XM2 (use the band button to switch sources), and on the unit itself it says Aux on the display.
    2015 Evo MR
  14. #14 Re: AUX Port...?
    Jan 2009
    Warsaw, IN
    Lol, him
    I went to crutchfield and input my car with the monsoon and it said it was compatible, but there was a side note type of deal that mentioned in some cases it may need to be programed. But he has to have the radio unlocked for his vin anyhow, so i don't think it would be to difficult if it had to be programed for the adapter.
    That adapter is expensive.
  15. #15 Re: AUX Port...?
    Edmonton AB
    I have done this in my 07 Grand Prix GT with the monsoon.
    Plug in and play. You'll need to tap into the power (thicker yellow cable from the connector from inside of the car) and then get a RCA to Aux so you can play your tunes.
    Hope that helps,
    -Garrett
  16. #16 Re: AUX Port...?
    London Ont, Canada
    $70 is cheap if you ask me!
    Once I pick up my 05 I'm totally looking into adding an aux port
  17. #17 Re: AUX Port...?
    Minnesota
    Quote Originally Posted by garreTT View Post
    Hope that helps,
    -Garrett
    Go straight from the fusebox. NEVER take power from the head unit.
    2015 Evo MR
  18. #18 Re: AUX Port...?
    Edmonton AB
    Any reason why? How would you hook it into the fuse box? My fuses are all on the passenger side of the car.
  19. #19 Re: AUX Port...?
    Minnesota
    Well first off you'd be hacking up the factory wiring lol, then there's the fact that the head unit has a built in amplifier (non-monsoon). Also everyone I've ever talked to has said to never take power from the HU so there's that, but I can't speak to the credibility of such statements. Look up add a fuse on Amazon, and there's a big metal piece in the fuse box with a hole in it I use for a common ground. You can just run the wires through the bottom of the dash under the paneling, completely out of sight.
    2015 Evo MR
  20. #20 Re: AUX Port...?
    one of these puppys work great, every auto parts store has them in the fuse section.
    Littelfuse FHA200BP ATO Fuse Add-A-Circuit KT
  1. port plans
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 04-02-2010, 06:46 AM
  2. How hard to port?
    By dagger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2010, 12:49 PM
  3. My S/C Port
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2009, 01:54 PM
  4. How to port your m90.
    By minichopper6hp in forum How To Write-Ups/Tech Tips
    Last Post: 09-03-2009, 04:32 PM
  5. Port my LIM???
    By YoungGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2008, 09:50 PM
