Thread: installing a OEM Navigation system in 08 GXP
Results 1 to 6 of 6
2008gpxman installing a OEM Navigation... 07-06-2010, 09:25 PM
CODFATHER Re: installing a OEM... 01-17-2013, 05:55 PM
jteske88 Re: installing a OEM... 01-17-2013, 06:12 PM
simbah Re: installing a OEM... 01-17-2013, 10:59 PM
Rob97gtp I don't think you have to... 01-17-2013, 11:20 PM
sasquatch094 Re: installing a OEM... 03-01-2013, 05:32 PM
  1. #1 installing a OEM Navigation system in 08 GXP
    SE Level Member 2008gpxman's Avatar
    Jul 2010
    st. cloud mn
    I just got a Navigation system and antenna off ebay and I want to install it in my 2008 GXP with Monsoon and Onstar. Has anyone done this and has any helpful advice? I have no idea where to mount the antenna, or how to link the vehicle speed sensor VSS? I know I will have to get it programmed by a tech II scanner, but that's all I know, can anyone help??
  2. #2 Re: installing a OEM Navigation system in 08 GXP
    Apr 2012
    Beaverton
    Did you ever figure anything out?? Im doing this in my 06. It will at least still work fine for a radio for the time being right? Hopefully this is a fairly simple swap
  3. #3 Re: installing a OEM Navigation system in 08 GXP
    Yoga city
    No it won't work, it will be locked until programmed at dealer.
  4. #4 Re: installing a OEM Navigation system in 08 GXP
    GTP Level Member simbah's Avatar
    Lala land
    The VSS should already be a part of the existing wire harness. As far as the NAV antenna I believe it is to be mounted in the front dash somewhere.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
    SE Level Member Rob97gtp's Avatar
    Jul 2012
    Kansas city
    I don't think you have to unlock nav radios it should work might sound funny or your steering wheel controls might not work or be backwards. If so it will need programmed. I think you will be able to plug and play tho. I would just put the antenna in the center if the dash closest to the windshield
  6. #6 Re: installing a OEM Navigation system in 08 GXP
    GT Level Member sasquatch094's Avatar
    cleveland
    any updates??
  1. Navigation System
    By Raybo in forum Audio, Security & Visual Electronics
    Last Post: 05-09-2009, 11:27 AM
  2. GTP/Navigation
    By josh04GTPCompG in forum Audio, Security & Visual Electronics
    Last Post: 05-07-2009, 01:32 PM
  3. Installing system in 2005 GP for first time
    By stoner17971 in forum Audio, Security & Visual Electronics
    Last Post: 03-03-2009, 10:46 PM
  4. Gm Navigation system
    By scoobyydooooooo in forum Audio, Security & Visual Electronics
    Last Post: 02-13-2008, 09:17 PM
