Do you have a factory amp? If so, it sounds like the rear channel is out (or going out). If you do not, your culprit is most likely the head unit. One speaker is not going to bring down others, as they are wired independently.
Does the car have factory bose ? If so they are infamous with age to start going out and will certain speakers will go off randomly.if it does have factory bose when replacing factory head unit you will be best off bypassing that amp.
