Thread: Need help with subs
Results 1 to 20 of 29
  1. #1 Need help with subs
    GT Level Member tyv193's Avatar
    Jul 2010
    Central Ny
    I got these subs for free and i would like to hook them up to the stock headunit in my gtp. Its a 2002 and has the bose system. If someone could explain to me the easiest way to hook these up that'd be great. I would really appreciate it. Here are some pictures. The owner before maybe had some hooked up? I think this is and amp of some kinda in the first picture. There are some others. Thanks.
    2002 GTP
  2. #2 Re: Need help with subs
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    The Wheelen CSP660 is a strobe power supply. Usually only used for Emergency vehicles. Police, Fire, Rescue etc. It is not an amp. Was your car a police vehicle???
    Lambokit to be built!!!!!
  3. #3 Re: Need help with subs
    Jul 2010
    Central Ny
    Yea i realized it was a strobe supply after I posted this haha. Says strobe supply.... and idk I still have the strobes they are in my headlights and tailights. They are blue but i dont think it was a police vehicle maybe volunteer firefighter?
    Anyways from further reading i realize i need a line output converter how should i go about connecting this and is it safe?
    2002 GTP
  4. #4 Re: Need help with subs
    SE Level Member djwright1980's Avatar
    tennessee
    The problem you are gonna have is the factory bose system.it is 8 ohm and even with a line converter.you want be able to get the full potential of your sub/amp.also hook line converter up to speakerwires from deck not from bose amp.
  5. #5 Re: Need help with subs
    Jul 2010
    Central Ny
    For right now i am going to keep my factory bose headunit. Will i be able to tell that the subs are there? So i hook up line converter to speaker wires. I can do this to the rear speakers in my trunk, the wires that go directly to my rear 6x9 speakers? splice the wires and then conect rca's to my sub amp?
    2002 GTP
  6. #6 Re: Need help with subs
    Apr 2009
    Radford, Virginia
    X2^^^, hook the line converter into a speaker wire from the radio not from the amp.
  7. #7 Re: Need help with subs
    Jul 2010
    Central Ny
    How do i know what wire is from the radio to the speaker ? Do i have to take out the head unit and look or can i look to see which line is coming from the amp and splice the other?
    2002 GTP
  8. #8 Re: Need help with subs
    Jul 2010
    Central Ny
    If someone knows how to hook this up itd be great
    2002 GTP
  9. #9 Re: Need help with subs
    tennessee
    The bose amp is in trunk find the input plug going into amp and splice the conververter into those.
  10. #10 Re: Need help with subs
    Jul 2010
    Central Ny
    Ok, thanks. Do i need another way to get power to them?
    2002 GTP
  11. #11 Re: Need help with subs
    Jul 2010
    Central Ny
    Car audio guy at best buy recomended this..
    Scosche - 2-Channel Adjustable Line-Out Converter - Clear - LOC80
    And then said to hook it up on the lines from bose amp to the rear speakers..
    You guys are saying to splice before the amp is there a reason for this?
    2002 GTP
  12. #12 Re: Need help with subs
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    With the line converter, the sound is going to differ in volume as the wattage is going to be different, so eliminating on variable makes the equation easier. The signal will be purer straight from the head unit, which will lead to better sound quality.
    The sub amp I assume has a low pass filter.
    if not then you need a way to block the highs as the signal your getting is full range.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  13. #13 Re: Need help with subs
    GT Level Member RamonGTX's Avatar
    menasha wisconsin
    These cars are such a pain in the ass when they come with bose...it took me 3 months to figure out how to put my new head unit and subs in...i put it in first and no sound from the speakers and after doing some researching and asking around i found out that there is 2 wire harnesses that come into the stock head unit one for speakers etc and the other for the steering wheel controls...well the steering wheel control harness has a pink wire on it and that is the remote turn on wire for the bose amp to get the speakers to turn on..i went to walmart and bought this...
    Buy.com - Scosche SLC4 Speaker to RCA Four Channel Line output converter
    this adapter also will work for what you wanna do since you can use it 3 different ways....plus it lets you adjust the speaker levels the way you want them.......
  14. #14 Re: Need help with subs
    Jul 2010
    Central Ny
    Thanks guys. Do you know how i am gonna be able to get power to them? Would i be able to get power from that strobe power supply some how instead of running all new wire?
    2002 GTP
  15. #15 Re: Need help with subs
    SE Level Member brian kuzminski's Avatar
    Nov 2010
    va beach
    i install those strobe packs in police cars all day be carefull they will light you up
    b.kuz
  16. #16 Re: Need help with subs
    Jul 2010
    Central Ny
    I wont touch it then
    2002 GTP
  17. #17 Re: Need help with subs
    Houston
    No, you will need to run a new power wire. Anywhere between 4 and 8 gauge, depending on the wattage of your amp. The lines to the strobe supply look too small.
  18. #18 Re: Need help with subs
    Jul 2010
    Central Ny
    Is there a special end that i need for it to compatible for my amp or any 4 or 8 guage will work?
    2002 GTP
  19. #19 Re: Need help with subs
    Houston
    Compatible? The sub amp will have nothing to do with the factory amp. Just run a 4 or 8 gauge power line from your battery to the sub amp. Find a grounding point in the trunk, and run the RcAs from the in-line to the sub amp.
  20. #20 Re: Need help with subs
    Jul 2010
    Central Ny
    Ok sounds good. Thanks
    2002 GTP
  1. New (to me) Subs
    By josemolina2008 in forum Audio, Security & Visual Electronics
    Last Post: 08-07-2010, 12:09 AM
  2. got subs...but what amp?
    By coreygnar in forum Audio, Security & Visual Electronics
    Last Post: 07-30-2010, 02:43 AM
  3. My new HID's and subs
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 06-27-2009, 09:55 PM
