Thread: New sub and amp setup
Results 1 to 20 of 25
  1. #1 Re: New sub and amp setup
    Feb 2009
    Virginia
    Ive never seen an SPL comp where their amp is directly in front of the sub like the pic he showed. If they are in front of the subs, they're usually mounted below the actual subs. And the quality of amps they use are usually better than bazooka.
    I guess my point was that it doesn't matter where you are in the vehicle, vibrations occur. I used SPL as an example because even at the windshield you're talking 150db's. That's more noise than majority of daily driver installs at a 1 meter distance. Best buy and Circuit City had installs like that all day. Daily routine is strap an amp to the back seat and put some subs next to it. I had subs firing at an amp for 5 years without issue. It's luck of the draw...but it's not placement of the amp, it's installation.
    11 is louder than 10!
  2. #2 Re: New sub and amp setup
    Houston
    I agree, installation is THE most important part. But why add extra vibration, if its not necessary. I was just trying to help him prolong his amps life.
    Edit: If you ever have best buy or the like, install your amp....double check to make sure they dont run the power with the signal wires. They like doing that.
  1. Setup to go for?
    By Dthreap in forum Turbo
    Last Post: 01-26-2010, 08:50 PM
  2. my old setup
    By whitcomb in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 06:49 PM
  3. New setup
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 02-25-2009, 11:00 PM
  4. this setup
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2008, 08:47 PM
