Thread: Rap Pop
Results 1 to 20 of 25
  1. #1 Rap Pop
    GTP Level Member TyroElite's Avatar
    Williamsport, PA
    No, not the music types but I've got a problem.
    When I turn my car off, the RAP keeps the radio on like normal. When I open the door, it turns off my radio but I get a loud pop through my subs. In case it matters, I've got an audiobahn amp and 2x12" subs. My HU is a dvd player combo unit from Panasonic I believe. Any ideas what could cause this?
  2. #2
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    have you had it tuned cause i knno some times when you have it set to sensitive or the frequency set wrong.
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  3. #3
    GT Level Member Chleby's Avatar
    Sioux Falls, SD
    my suggestion is to just turn it down before you turn it off and if you still have this problem you probably have the remote wire for the amp hooked to the accesory power rather than the remote power lead
    2001 Grand Prix GT...turbo build soon to come
    http://www.cardomain.com/ride/2618949
    Andrew Chleborad....Sioux Falls, SD
  4. #4
    Williamsport, PA
    It happens even if the radio is off. So maybe I do have the wire wrong. I'll have to check on it. I'm pretty sure I only have a remote power wire though. I'll check on it. Thanks.
    What do you mean by Tuned? The amp tuned you mean?
  5. #5
    Jan 1970
    Maquoketa, Iowa
    the amp, yah... I'm gettin a system on the 2nd, I need to know how to tune mine too... anybody got a write-up??
  6. #6
    wamego,KS
    Quote Originally Posted by TyroElite View Post
    yes i mean the amp but id deffinenlty check that wire since it does it even when it is off.
  7. #7
    wamego,KS
    i ve always played it by ear just playing wit frequecies and most of the time a sub will have frequency ranges you should try to stay within bbut if at all possible find some one to tune it o and make sure the subs are not playing the words.
  8. #8
    Sioux Falls, SD
    Quote Originally Posted by MTXGTP View Post
    getting ur system tuned doesn't necessarily mean cutting out the vocals...basically what u do when u tune a system is making sure that your subs aren't putting out any frequencies that ur other speakers are other wise whater band is crossingis going to stick out from the rest of the music...
    so say ur speakers on your rear deck and front door will put out anywhere from 20k Hz to 45 Hz you'll want to tune your subs so that nothing above 45 Hz is being played through your subs...
    on another note it works the same way if tou have seperate tweeters up front u dont want the door speakers and the tweeters to put out the same frequencies
  9. #9
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    are you still having this problem? If so, There are a couple of things I would try.
    1) try regrounding the amp to a different spot,or clean off the area it is grounded to better, make sure it is bare metal.
    2) try turning the gain down on the amp, sometimes when the gain is turned up way high, it causes a loud turn off pop.
    3)Use a relay to actually turn on the amp, this is more typical when you use more than 2 amps to boost the turn on voltage, but it can atually get rid of the turn off pop.
    -steven-
  10. #10 Re: Rap Pop
    Saraland Alabama
    Quote Originally Posted by s1795so2 View Post
    -steven-
    I agree especially the relay, the audiobahn amps are very prone to those pops
  11. #11
    GT Level Member mlambert's Avatar
    A house
    What you are getting is commonly referred to as a "clip out". I get this a lot at clubs I DJ at where the mixer has the gains up way too high for what the subs can actually handle, most especially when the subs are all pointed at each other, so that would explain why it's only going on with your door panel units. This is also the number one killer of subs. (Edit: Well, crap. I re-read your entire post again. Is it going on with your door panel ones or just the rear deck or both?)
    What you want to do, since I'm betting your head unit a lot like my panasonic, is go into your menu features and flatline everything. If you only have settings for treble and bass, just put them both at medium. Make sure your subs are tuned for the lower frequencies only, and I'm betting you'll see that your subs are set for mids and lows. Which is probably what is creating the problem. Most of the time I see what you're getting it's because the default settings on the head unit is telling your subs to handle everything but highs. Bad bad bad.
    My system also has a separate knob for the gain on the subwoofers. I call it the cop killer because they write tickets here for disturbing the peace. I can easily crank that all the way down anytime I see a local around.
    Once you get everything flatlined, you can stage your sound the way you want it. I tech mine to female rock vocals, which seems to work perfectly. If you do the vocals and the high percussives first, it is easy to add everything else in.
  12. #12
    alhambra, Il
    [QUOTE=TyroElite;3536]but I get a loud pop through my subs. [QUOTE]
    hes getting the noise through his subs, not any of the speakers. It is the turn off pop, because the amp is not being told to turn off when everything else is.
    The noise is like a very short test tone being played through the subs.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  13. #13
    Williamsport, PA
    Exactly. It never happens when I have the music playing so its not the clipping you're speaking of.
  14. #14
    A house
    OIC.
    Annoying just the same...
  15. #15 Re: Rap Pop
    SE Level Member deft's Avatar
    pennsdale, PA
    i had the same thing in my bonerville...moved the system over to other cars and havent had the same results....only differences was wiring harness and where it was grounded.
    2007 GXP: Magnaflow Cat-back, F/R STB, MSP Poly Motor Mount, Kicker 15" Solobaric, ZR1000, Pioneer HU, Donrome Locks, Custom FWI, HP tune in progress
    1999 se: k&n, dhp pcm, perf shift knob, flipped motor mounts, HIDs
  16. #16
    alhambra, Il
    did you try the 3 things I reccomended yet? I was just wondering if those cured it or not because they really should.
    -steven-
    Steven Oliver
  17. #17
    Williamsport, PA
    I haven't yet since its been about 20 degrees here lately and i've got no garage. Its supposed to warm up this week so I'll deffinately check on it then.
  18. #18 Re: Rap Pop
    Williamsport, PA
    Hmmm... never would have thought about the relay idea. Might have to look into that.
    I do know my ground spot isn't the greatest but it was all I could come up with at the time. My amp is mounted to the top of my box so the only close spot for a ground (that wasn't drilling through my rear shelf somehow) was to my strut tower. I did sand it off but perhaps not well enough. Where else would you suggest the ground to go?
    And my gain isn't turned up much at all right now. about half if that.
  19. #19 Re: Rap Pop
    alhambra, Il
    i am not saying you can have a 50 foot ground here, but you can have a decently long ground as long as it is to a good piece of bare metal, not a secondary piece of metal. I grounded mine on the passenger side right beside the hump the the tire is. I am pretty sure you can see it in one of the pics I posted up in the audio section. That should be a good starting point.
    Steven Oliver
  20. #20 Re: Rap Pop
    Sioux Falls, SD
    i personally have my amp grounded to the seatbelt bolt
pop, rap
