s1795so2
are you still having this problem? If so, There are a couple of things I would try.
1) try regrounding the amp to a different spot,or clean off the area it is grounded to better, make sure it is bare metal.
2) try turning the gain down on the amp, sometimes when the gain is turned up way high, it causes a loud turn off pop.
3)Use a relay to actually turn on the amp, this is more typical when you use more than 2 amps to boost the turn on voltage, but it can atually get rid of the turn off pop.
-steven-
