Thread: Rap Pop
Results 1 to 20 of 25
  1. #1
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    i ve always played it by ear just playing wit frequecies and most of the time a sub will have frequency ranges you should try to stay within bbut if at all possible find some one to tune it o and make sure the subs are not playing the words.
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  2. #2
    GT Level Member Chleby's Avatar
    Sioux Falls, SD
    Quote Originally Posted by MTXGTP View Post
    getting ur system tuned doesn't necessarily mean cutting out the vocals...basically what u do when u tune a system is making sure that your subs aren't putting out any frequencies that ur other speakers are other wise whater band is crossingis going to stick out from the rest of the music...
    so say ur speakers on your rear deck and front door will put out anywhere from 20k Hz to 45 Hz you'll want to tune your subs so that nothing above 45 Hz is being played through your subs...
    on another note it works the same way if tou have seperate tweeters up front u dont want the door speakers and the tweeters to put out the same frequencies
    2001 Grand Prix GT...turbo build soon to come
    http://www.cardomain.com/ride/2618949
    Andrew Chleborad....Sioux Falls, SD
pop, rap
