First, in no way did I use "watts" as if you didn't have a clue.
Is your intention with these questions that have nothing to do with the Big 3 to make me look stupid? I guess I'll try my best to answer them...
Power (watts) is the measure of the rate of energy consumption in Joules per second. Having a dynamic power draw is as simple as having a constantly changing power draw, much like an amplifiers power draw when playing music.
If you hook up a tweeter to an amplifier and send a 100 watt rms signal to it, it will probably blow, unless of-course you are sending a signal which is being suppressed by a filter. Then again you said a "100-watt" channel not a 100 watt signal... so there could be a lot of things effecting why that tweeter isn't blowing.
The average power consumed by your amplifier doesn't need to be defined by RMS because its not an AC signal.
I did mention "High-power" car-audio applications in my previous post, I will assume you missed that because I think you are smart enough to realize that 10 watts of power output is not by any means "high". I did google the brand though and saw they were rated at .005%THD, this most likely means they can put out a lot more than 5 watts of power per channel before clipping.
I also never claimed that you NEED the Big 3. I simply said it was an inexpensive upgrade that is worth doing. While I realize that a solid sine wave is much different than the complex dynamics of music, I myself listen to music where the bass will stay solid and loud for 3+ seconds, this means a fairly constant power draw for an extended period of time. Feeding 150 amps through an 8 gauge wire for extended periods of time will cause the wire to become extremely hot, to the point of melting the shielding even. The voltage drop from such a thin wire will reach over 1/2 a volt, robbing your system of power.
I understand where your coming from and I admit I'm not a car audio guru; but, my question to you is... why not? It is an easy upgrade... a cheap upgrade... and can help sort out voltage drops. Why not do it? Also, Iceroyal never commented on whether or not he planned on competing, if he does than thats even MORE reason to maintain high voltage.
