Thread: I Need Ideas
Results 1 to 20 of 39
  1. #1 Re: I Need Ideas
    SE Level Member iceman977th's Avatar
    KY
    Quote Originally Posted by shawnschuldt View Post
    trunk space i dont care about i just want to design a box i dont need to build in the trunk so it can be removed and coated in the summer. so im thinking im going to fire them up and make each sub its own box the only part im undecided with is the port. i have a design i can pm you and see if there is something i can improve on
    Well you're looking at at minimum 3 cubes per sub to make them sound good, so if you aren't worried about trunk space, you're looking at about 3ft x 3ft x 1 1/3ft box. You have two options though. Either rear firing & deaden your trunk, or front firing & seal the trunk off from the cabin completely.
    Me personally, I'd say make a trapezoid-shaped box (in regard to the side) firing backward. That's just me though. Are you wanting a nice box or just functional?
    2001 Grand Prix GT Sedan Silver :: Sony CD-GT54UIW :: Clarion EQS746
    2x Audioque SDC2.5 12" D4 + Audiopipe AP1500.1D :: 4 cu ft @ 32Hz, 1500w @ 1ohm
    Crescendo CCX65 Doors :: Pioneer 6x9 Rear :: Cadence CRS-Z9 4ch
  2. #2 Re: I Need Ideas
    GT Level Member shawnschuldt's Avatar
    Jun 2010
    Beloit, WI
    This is basically what i was thinking so far its 17"w x 30"L x 14"H Its right around 3 cubes before displacement and tuned to 32Hz if u think i should add a little more volume i can take it from 30" to 35" but keep in mind i need to get 2 of these side by side in my trunk fairly easily. when i get a chance i gotta cardboard these and see if this design will even go in i think it will tho
  1. Need some ideas
    By tyv193 in forum Off Topic Discussion
    Last Post: 11-22-2010, 05:00 PM
  2. Any ideas?
    By IBurnCamaros in forum Visual/Body Modifications
    Last Post: 10-03-2010, 04:47 PM
  3. tattoo ideas for my cast! post your ideas!
    By putskijr in forum Off Topic Discussion
    Last Post: 07-11-2010, 04:53 PM
  4. ideas
    By Will5600 in forum General Tech Discussion
    Last Post: 03-18-2010, 07:27 AM
  5. Ideas Anyone?
    By BwolfGT in forum Visual/Body Modifications
    Last Post: 11-13-2008, 06:39 PM
