Just post what you've got for a design on here so we can all help you out
Also I'll help out with the design and measurements and whatnot if you want too
Well you're looking at at minimum 3 cubes per sub to make them sound good, so if you aren't worried about trunk space, you're looking at about 3ft x 3ft x 1 1/3ft box. You have two options though. Either rear firing & deaden your trunk, or front firing & seal the trunk off from the cabin completely.
Me personally, I'd say make a trapezoid-shaped box (in regard to the side) firing backward. That's just me though. Are you wanting a nice box or just functional?
http://i227.photobucket.com/albums/d...ireframe-1.jpghttp://i227.photobucket.com/albums/d...earVent-X2.jpgThis is basically what i was thinking so far its 17"w x 30"L x 14"H Its right around 3 cubes before displacement and tuned to 32Hz if u think i should add a little more volume i can take it from 30" to 35" but keep in mind i need to get 2 of these side by side in my trunk fairly easily. when i get a chance i gotta cardboard these and see if this design will even go in i think it will tho
Whats the length of the piece inside the box making the port? and what is your port opening size?
Looks really nice!
the piece for the vent is 23 almost 24 inches long overall the vent is 15.5"x2"
Last Q, is there a quick way to convert those measuments to fit a 12" sub.??
I forgot in your OP that you're making this box for a 15" sub, I'm looking for a new 12" (i have a simple Sony xplod right now (college budget)) and was looking to make the box before hand. If you dont want to sent specific measurement, would I be safe just knocking off an inch for the box and a little less than an inch for the vent opening?
Sorry where would the port be facing?
It also shouldnt be that close to the bottom if you're going to lay it down as pictured. It would lower your flowing capabilities.
http://i1125.photobucket.com/albums/...8/IMAG0395.jpg
http://i1125.photobucket.com/albums/...8/IMAG0396.jpg
http://i1125.photobucket.com/albums/...8/IMAG0397.jpg
And yeah I know that the port is huge they aren't technically subs they're just lower frequency speaker used for dj setups.
For slot ports I'm not sure but for tubs its the diameter of the port.
I'd venture to guesstimate the height of the port.
Taking a router to the corners of the port would help with flow as well.
Have you decided on a driver yet? I could run some sims to find out how close you are to the limits of port flow.
i dont have anything crazy the subs that im moving from my old vehicle to my new one are alpine type-r 15's swr-1522d, as far as power it will be the same as my old vehicle about 1300watts rms
oh and i forgot if you could check that out it would be great with the current design i think i only have about half an inch more i could open it up before it gets too long or i can take the tune from 32 to 35 according to bbp 6 max air veloicity for that box right now is 25m/s
25 m/s is good.
27 is max IIRC. 25 being ideal.
Still dont like the idea of firing into the trunk though.
I think you should pull the rear 6x9's and 4's if you have 'em, if not, just pop out the pre-cut insulation in the rear deck and install a bose rear deck lid.
Then have the ports sealed to those holes.
Exactly... I haven't done this myself seeing as my box is sealed so I can't really show you.
But both holes are open since my 6x9's took a dump.
Shawn, I pmd ya.. just curious as the Height and Width for a 12" sub
Thanks.
