Thread: Installed OEM Nav
Results 1 to 10 of 10
  1. #1 Installed OEM Nav
    Donating Users richhurl's Avatar
    Shelton, CT
    Replaced the stock radio with the OEM Nav. For anyone doing it, you need to run the wire for the VSS and also install the Nav attenna under the dash. Dealer did the programming.
  2. #2 Re: Installed OEM Nav
    Hurst, TX (DFW)
    How much was the programming?
  3. #3 Re: Installed OEM Nav
    Jul 2010
    Where did you get the OEM nav from? And what year is your car?
  4. #4 Re: Installed OEM Nav
    Aug 2008
    KCMO
    subscribed
  5. #5 Re: Installed OEM Nav
    Shelton, CT
    Here is the breakdown, my car is an 08 GXP:
    OEM NAV radio - $600 (replacementradios.com)
    OEM NAV antenna - $80 (replacementradios.com)
    NAV unit physical installation - Did myself
    Program NAV unit - $90 (dealer 1/hr)
    Run wire for VSS - $180 (dealer 2/hrs)
    OEM NAV CD - $60 (Ebay)
    The wire for the VSS took longer for the tech to do because he needed to test by first running the wire outside the car first to see if it would work. But the VSS connection is needed otherwise the NAV will need to get your exact position via GPS and the turn-by-turn won't work well.
    Expensive, yes, but very cool having the OEM NAV and the radio functions with a touch screen. Plus it does add value to the car.
    I have a picture of it, but can't seem to get the file to upload.
  6. #6 Re: Installed OEM Nav
    Jul 2010
    Damn!!! $1010! Holyyy hellllll. It would be sweet. But I don't think I could drop that much on it.
  7. #7 Re: Installed OEM Nav
    Shelton, CT
    Yep, it was expensive. But I did spend less then 1/2 of the $2,145 list price for the option.
    Plus the heads-up turn-by-turn is a great feature.
  8. #8 Re: Installed OEM Nav
    SE Level Member Alexaloisio's Avatar
    Lockport, ny
    i dont see the oem navi radio you used. which one is it?
  9. #9 Re: Installed OEM Nav
    Aug 2008
    KCMO
    he prolly bought the last one they had in stock at the time
  10. #10 Re: Installed OEM Nav
    Shelton, CT
    Bought the OEM GM part number 10391240. I think it was the last one in stock, but they usually get more in stock at some point.
  1. HID's installed!!!!!
    By tmackster in forum Visual/Body Modifications
    Last Post: 10-23-2009, 09:57 PM
  2. TDC FWI installed
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2009, 10:49 AM
  3. Stb's Installed
    By TML529 in forum Brakes/Suspension/Chassis
    Last Post: 04-26-2009, 12:39 AM
  4. Got the new DP installed, but...
    By the1euge in forum General Tech Discussion
    Last Post: 07-21-2008, 08:07 PM
  5. First Mod installed. CAI
    By scoobyydooooooo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2008, 08:41 AM
