Here is the breakdown, my car is an 08 GXP:
OEM NAV radio - $600 (replacementradios.com)
OEM NAV antenna - $80 (replacementradios.com)
NAV unit physical installation - Did myself
Program NAV unit - $90 (dealer 1/hr)
Run wire for VSS - $180 (dealer 2/hrs)
OEM NAV CD - $60 (Ebay)
The wire for the VSS took longer for the tech to do because he needed to test by first running the wire outside the car first to see if it would work. But the VSS connection is needed otherwise the NAV will need to get your exact position via GPS and the turn-by-turn won't work well.
Expensive, yes, but very cool having the OEM NAV and the radio functions with a touch screen. Plus it does add value to the car.
I have a picture of it, but can't seem to get the file to upload.
