Thread: Satellite Radio
Results 1 to 5 of 5
  1. #1 Satellite Radio
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    My SS didn't come with satellite radio. I want to keep the factory radio and add satellite. I don't want two antenna's on the roof, can I just buy the one of these http://cgi.ebay.com/ebaymotors/GM-GM...fAudioQ5fVideo. Replace the antenna with an xm/onstar unit, the necessary wiring and plug everything in? I' know I have to subscribe to the get satellite service.
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  2. #2 Re: Satellite Radio
    Hurst, TX (DFW)
    I am not sure if the factory radio will have the necessary XM connections to work with that tuner. Have you pulled the radio to check? Either way you will need an antenna for the XM to work.
  3. #3 Re: Satellite Radio
    New Brunswick
    If your deck is an 03 or newer it will work, however you will have to add connectors to hook it up...not very big of a job if your electrically knowledable. you can simply get an onstar antenna with xm built in...these will have 3 seperate connectors the two seperate connectors for onstar and a third for xm.
    Used XM Modules...upon installation you will get the xm locked message as soon as the key reaches the on position...the dealer themselves CANNOT clear theft lock on xm modules...headunits they can though.
    So what needs to be done is the module either be sent to a delphi service center to clear the eeprom or purchase a new module from the dealer...
    I installed factory XM twice on grand prixs, first was on my 04 i got lucky and got a new module on ebay, however that car got wrecked so i did the same thing on my replacement 06 and ended up having to buy a new XM Module.
    I think yours is an 05 which i think it is, you have the class 2 data bus so the module must be meant for vehicles like an impala03-05, grand prix, up until 06 silverados and sierras, canyons and colarados and equinoxes. pretty much everything else is GM LAN.
    Actually I found a nice list, any one of these and they will work...
    EQUINOX 06 SAT recvr (opt U2K), ID 10333560
    MONTE CARLO 05 SAT recvr (opt U2K), ID 15125061
    UPLANDER 07 SAT recvr (opt U2K), w/Multi media-Audio/Video/Videogame (opt UMS)
    ALLURE 05 SAT recvr (opt U2K)
    CTS 05 SAT recvr (opt U2K), ID 10333560
    MONTANA 06 (SV6), SAT recvr (opt U2K), ID 15125061
    RELAY 05 SAT recvr (opt U2K)
    SILVERADO 2500 PICKUP 04-05 SAT recvr (opt U2K)
    TORRENT 06 SAT recvr (opt U2K), ID 15125061
    YUKON XL 1500 04-05 SAT recvr (opt U2K)
    SIERRA 1500 PICKUP 04-05 SAT recvr (opt U2K)
    SIERRA 2500 PICKUP 04-05 SAT recvr (opt U2K)
    SUBURBAN 2500 04-05 SAT recvr (opt U2K)
    UPLANDER 05 SAT recvr (opt U2K)
    EQUINOX 06 SAT recvr (opt U2K), ID 15125061
    TERRAZA 07 SAT recvr (opt U2K), w/Multi media-Audio/Video/Videogame (opt UMS)
    YUKON XL 2500 04-05 SAT recvr (opt U2K)
    AVALANCHE 2500 04-05 SAT recvr (opt U2K)
    LACROSSE 05 SAT recvr (opt U2K)
    MONTANA 07 (SV6), SAT recvr (opt U2K), w/Multi media-Audio/Video/Videogame (opt UMS)
    UPLANDER 06 SAT recvr (opt U2K), ID 15125061
    SRX 05 SAT recvr (opt U2K)
    SILVERADO 1500 PICKUP 04-05 SAT recvr (opt U2K)
    GRAND PRIX 07 SAT recvr (opt U2K), ID 15125061
    SILVERADO 3500 PICKUP 04-05 SAT recvr (opt U2K)
    YUKON 04-05 SAT recvr (opt U2K)
    AZTEK 05 SAT recvr (opt U2K)
    ESCALADE 04-05 SAT recvr (opt U2K)
    ESCALADE EXT 04-05 SAT recvr (opt U2K)
    TERRAZA 06 SAT recvr (opt U2K), ID 15125061
    ESCALADE ESV 04-05 SAT recvr (opt U2K)
    RENDEZVOUS 04-05 SAT recvr (opt U2K)
    TAHOE 04-05 SAT recvr (opt U2K)
    TORRENT 06 SAT recvr (opt U2K), ID 10333560
    MONTANA 05 SV6, SAT recvr (opt U2K)
    AVALANCHE 1500 04-05 SAT recvr (opt U2K)
    IMPALA 05 SAT recvr (opt U2K), ID 15125061
    CTS 05 SAT recvr (opt U2K), ID 15125061
    SIERRA 3500 PICKUP 04-05 SAT recvr (opt U2K)
    SIERRA DENALI 04-05 SAT recvr (opt U2K)
    SUBURBAN 1500 04-05 SAT recvr (opt U2K)
    RELAY 06-07 SAT recvr (opt U2K), ID 15125061
    TERRAZA 05 SAT recvr (opt U2K)
    Theres a company called instrument sales and service or somethign like that mentioned on this link that reflashes the eeprom on the modules...
    "XM Lock", "XM Locked", or "XM Theftlocked" Issue Resolved! - Corvette Forum
    I walked a guy through installing xm on his prix and this is the route he took...worked perfect for him.
    Heres the thread on installing XM on a prix, connectors arnt the same in certain parts of the car since its a grand prix but there is alot of valubale information otherwise.
    Grand Prixs Of North America • View topic - Factory XM install????
    Do you have access to wiring diagrams and such for your ss? if not I can get some.
  4. #4 Re: Satellite Radio
    Jan 2009
    ny
    Thanks for the info, no I don't have the wiring diagram and would appreciate your help in area as well.
  5. #5 Re: Satellite Radio
    New Brunswick
    Good news I have found a way to unlock these things yourself...
    Grand Prixs Of North America • View topic - Remove XM THEFTLOCK From Used XM Modules Yourself.
    I also pm'd you for an email to send the diagrams, Anyone else who needs them can pm me as well
  1. CB Radio's
    By Thunderturd in forum Audio, Security & Visual Electronics
    Last Post: 09-14-2009, 08:27 PM
  2. New Radio
    By chuy09 in forum Audio, Security & Visual Electronics
    Last Post: 06-25-2009, 09:06 PM
  3. 04+ radio in 97-03 gp
    By isucyclones3 in forum Audio, Security & Visual Electronics
    Last Post: 06-01-2009, 01:20 AM
  4. Radio and HUD
    By the955iman in forum Audio, Security & Visual Electronics
    Last Post: 02-08-2009, 03:17 PM
