Thread: Climate Control Lights Going Out?
Results 1 to 5 of 5
  1. #1 Climate Control Lights Going Out?
    Indianapolis, IN
    Hey I have searched through the forums and basically have found out that I will be taking a trip to radio shack to replace the bulbs in the unit. This is for an 06 GP with Dual Climate control. Does anyone know if the bulbs in these are red or white or a mix of the two? I would really like to know what I am looking for before I pull the unit out. Since my mother has done military grade soldering for 30+ years I will more than likely pass the board to her expert hands.
    Also I was wondering something since I have bought the car. I am not sure if this is the climate conrol or what but since I have had it my car will occassionally make a humming noise in the dash. I think more on the drivers side. I always thought it was must an actuator or something opening a door or the car doing some kind of 'testing' but have no clue? It has started to do it more frequently in the last few months but not all the time. Also in the winter it tends to do it all the time. Anyone have a clue?
    Thanks
  2. #2 Re: Climate Control Lights Going Out?
    Nov 2010
    Ontario, Canada
    I've been searching the board for a couple of hours and you seem to be having the exact same issues as me - mine's an '08.
    The heated seat and up arrow for heat on the passenger side randomly went out a couple of days ago. Can anybody tell me the specs on the bulbs to replace?
    I've also had the rattle/hum sound coming out of the steering console area - always gets worse in the winter.
    Any suggestions?
    Thanks
  3. #3 Re: Climate Control Lights Going Out?
    Indianapolis, IN
    i think I know exactly what your talking about with that to. Mine sounds like a mechanical noise/hummm. almost like an electric motor or something. And yes mine gets worse in the winter/cold as well.
    What the Heck is it!????
  4. #4 Re: Climate Control Lights Going Out?
    Apr 2009
    Madison, WI
    Bump...I have the exact same problem with the climate control lights. Up temp and heated seats aren't lighting. I just put an aux input jack into the stock radio. It was a wiring harness adapter that was used. Anyone else find a solution. I'll check all the connections soon.
    Anybody....
  5. #5 Re: Climate Control Lights Going Out?
    Apr 2009
    Madison, WI
    Bump
    Anybody....
  1. climate control
    By buster in forum General Tech Discussion
    Last Post: 07-21-2011, 05:03 PM
  2. Climate Control
    By GrandprixGearhead in forum General Tech Discussion
    Last Post: 10-30-2009, 11:47 AM
  3. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
  4. climate control
    Last Post: 01-27-2009, 09:10 PM
  5. Automatic CLimate control lights.
    By RichCresci in forum Visual/Body Modifications
    Last Post: 08-15-2008, 09:35 AM
