Thread: climate control
Results 1 to 4 of 4
  1. #1 climate control
    Windsor Ontario
    My climate control exterior temperature wanders all around. Starts at freezing and usually goes to like 100 degrees and it's winter. So the car senses that its hot out and shuts off the heat. Is the sensor screwed up? Can I just clean it? Any help/opinions would be great.
  2. #2 Re: climate control
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    It's called the ambient air temperature sensor and is located in about the middle of the vehicle, well in front of the radiator. there's nothing to clean. $10 should get you a new sensor and fix your problem.
  3. #3 Re: climate control
    Windsor Ontario
    hey, $10 fixes are great,
  4. #4 Re: climate control
    SE Level Member GEMINIokc's Avatar
    Dec 2008
    n side
    so did this fix ur problem?
    UPDATED MODS....GreenBastard HP powertune, CAI, BlueGTP91 Engine bay detail, Finished painted Dash,Hogans Performance DP, Flow Master 40's, Still Missing driver side badge 4 weight reduction.... More Mods Coming Soon!!
  1. Climate Control Knob
    By cutiger80 in forum General Tech Discussion
    Last Post: 04-03-2010, 06:39 PM
  2. Climate Control Issue - Help!
    By sb7605 in forum General Tech Discussion
    Last Post: 12-17-2009, 10:50 AM
  3. Climate Control
    By GrandprixGearhead in forum General Tech Discussion
    Last Post: 10-30-2009, 11:47 AM
  4. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
  5. climate control
    Last Post: 01-27-2009, 09:10 PM
