Thread: LED's questions.
Results 1 to 3 of 3
  1. #1 LED's questions.
    Donating User Odi's Avatar
    Chicago South Suburbs
    Ok guys here I go.
    1. My front LED SMD's for the turn signals light up but turn off when turn signal is on. Same with hazards. Turn signal markers on the cluster are dimly lit and turn off when i try to use the turn signal. Suggestions? These are the bulbs: Pair 3157 3057 3357 3457 SMD 18-LED Lights Bulbs Amber% | eBay
    2. When I put the EP28 Tridon LED Relay boostjunkie used in his writeup my 3rd brake light would be constantly on. I got SMD LED's in there. Suggestions?
  2. #2 Re: LED's questions.
    Jun 2011
    Pepperell MA
    I dont currently have LED's anywhere on my car. But I can relate to this I think. When I bought my car the high beam indicator on the dash was dimly lit. When I would activate the high beams one of the bulbs would go dim. It was actually worse. This is because the car had two different headlight bulbs in it. Once I replaced them everything was fine and the dimly lit indicator lamp was gone.
    Im pretty sure when you swap out turn signal bulbs for led's it confuses the system and it thinks a bulb is out. I believe thats why my high beam indicator was dimly lit like your turn signal indicators.
    For the turn signals replace the flasher relay with one designed to work with led bulbs. Some people wire up load resitstors but they get hot and defeat the real purpose of led lighting. Lower power consumption,
    As for your third brake lamp make sure the relay is wired correctly. Or that the relay is not dead or malfunctioning.
  3. #3 Re: LED's questions.
    The relay supports LED's thats why Im so confused about that.
  1. some questions
    By NewGPkid in forum General Tech Discussion
    Last Post: 10-04-2010, 08:39 PM
  2. New-ish GTP questions
    By Fast50dz in forum General Tech Discussion
    Last Post: 04-01-2010, 12:55 AM
  3. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  4. 04+ FWI Questions
    By ZR1Vette09 in forum General Tech Discussion
    Last Post: 11-11-2009, 12:43 AM
  5. New - A few questions please
    By lioneyes in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-02-2008, 07:48 PM
