ok here we go, those are dual voice coil (DVC) subs so its 4 ohms per sub and you are gettin two, each coil can handle 500 watts RMS or 1000 watts RMS per sub. the amp is 4 ohm stable and is good for 500 watts RMS or 2 ohm stable and good for 1000 watts RMS. SO if the coils on the subs are wired into series (8 ohm load per sub) and the subs wired to the amp in parallel, that would be a 4 ohm load to the amp. it wouldnt damage anything but you would be gettin only half the power out of your subs. i say get an amp that is good for 1000 watts at 1 ohm and that way you can wire the subs in parrallel (2 ohms per sub) and wire them to the amp parallel and you would get a 1 ohm load and get the full potention of your subs without damaging anything
